callum wrote:
1. does the ignitor need to be bolted to the chassis? as i just pluged them in but never bolted them in to the car when i tested them.
callum wrote:Hmm that pretty much rules out the ignitor then.
Could I have
some type of air lock in the injection system?
How would I diagnose that?
callum wrote:Ok cool. That counts that out. Is there any way to check if the I injector
is being sent a signal to work? Is there any way I could
put a mutlimeter on the plug and crank the engine over that would work?
Cheers again for any help.
callum wrote:I put a test light on one of the injector plugs and it glowed so I'm assuming that since they have a signal and fuel that fuel probably isn't the issue.
That leaves spark. I will test the ignitors tomorrow to make sure they work and will test the ecu's at the same time.
If they both work what would be the next step?
Harlet wrote:Check the fuel pump is working, my 4E did that same thing right before the earth wire detached itself thanks to bio fuel.
cat007 wrote:Harlet wrote:Check the fuel pump is working, my 4E did that same thing right before the earth wire detached itself thanks to bio fuel.
I'm curious how a specific fuel managed to detatch a wire....?
