Panel Filter Replacement
Postby metal_sean_head » Tue Mar 09, 2010 12:32 pm
I tried searching but can't seem to find anything so can someone with an AE92 1989 FXGT corolla hatch please measure the dimensions of the standard air panel filter in the factory airbox as im looking at purchasing an aftermarket filter?
Big Port redtop if this helps
Im looking at this sort of thing
http://www.trademe.co.nz/Trade-Me-Motor ... 61456.html
Ive been on the ryco website but i just need the dimensions to be sure.
Or if someone can send me the appropriate link to the ryco website for the correct filter.
My car is not with me and i won't get a chance to measure it for a month or so ,so i can't measure it sorry.
Any help would be appreciated.
Or if anyone else has any suggestions other than an aftermarket filter in the factory airbox that is relativly cheap this would be appreciated aswell.
Thanks guys.
metal_sean_head
Postby FLAWLES » Tue Mar 09, 2010 1:38 pm
inter net is one of your freinds mate
http://www.rycofilters.com.au/catalogue ... /part/A459
FLAWLES
Postby metal_sean_head » Tue Mar 09, 2010 4:02 pm
Would you say going with an aftermarket panel filter is my best option for relative cheapness?
metal_sean_head
Postby Bling » Tue Mar 09, 2010 4:31 pm
I run a K&N panel filter in my car, but used to run a boring standard filter, no noticeable performance difference. imo.
Postby metal_sean_head » Tue Mar 09, 2010 4:37 pm
Would i be better off to get some pipe and some silicone joiners and a Decent pod filter and make up some sort of intake pipe? Locate the Pod somewhere in the bumper. Not sure how much room i will have as the car is a while away from me atm.
What have other people done?
Not wanting to spend a huge amount.
Is it worth the gains?
Thanks
metal_sean_head
Postby sergei » Tue Mar 09, 2010 4:58 pm
metal_sean_head wrote:Would i be better off to get some pipe and some silicone joiners and a Decent pod filter and make up some sort of intake pipe? Locate the Pod somewhere in the bumper. Not sure how much room i will have as the car is a while away from me atm.
Thanks
Short answer Nope.
Keep airbox. Unless big cams+ecu+what else you have.
Postby metal_sean_head » Tue Mar 09, 2010 6:17 pm
Standard airbox with aftermarket panel filter or just leave the filter as is.?
metal_sean_head
Postby petrolhead » Tue Mar 09, 2010 9:01 pm
you will generally not get any noticeable gains with an aftermarket filter and standard intake. Have a look at www.autospeed.co.nz and search for cold air intake. Here is a good page to look at too, it is what i am setting up on my ae92 http://www.autospeed.co.nz/A_110824/cms/article.html
Hewies
Race and Restoration
petrolhead
