spark plugs cracking
Postby tsoob » Tue Mar 09, 2010 4:57 pm
why would a nissan RB crack the no1 plug, i.e. it cracks the porcelian bit.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Re: spark plugs cracking
Postby sergei » Tue Mar 09, 2010 5:00 pm
tsoob wrote:why would a nissan RB crack the no1 plug, i.e. it cracks the porcelian bit.
any cold water getting there?
Postby iOnic » Tue Mar 09, 2010 5:37 pm
Just randomly or has it happened to a few? Might have had a hairline fracture when the plugs were installed and it's vibrated into a complete crack?
Postby rx7guy » Tue Mar 09, 2010 7:58 pm
I had a bluetop with ignition timing ridiculously out which cracked a bunch of plugs.
The torque band is wide and the road is narrow
rx7guy
Postby MAGN1T » Tue Mar 09, 2010 9:54 pm
Detonation does it.
It also breaks pistons and unseals headgaskets.
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby tsoob » Wed Mar 10, 2010 10:04 am
iOnic wrote:Just randomly or has it happened to a few? Might have had a hairline fracture when the plugs were installed and it's vibrated into a complete crack?
thats my thoughts or
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby tsoob » Wed Mar 10, 2010 10:05 am
MAGN1T wrote:Detonation does it.
Steve
this.
its running 15psi boost standard ecu
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby JustinSpiderholden » Wed Mar 10, 2010 12:29 pm
Steve
this.
According to Magnit only idiots use aftermarktet ecus becasue they are not capable of making maxium use of the stock one
Come on Guys, don't question Magnit he knows more than all of us
JustinSpiderholden
Postby rollaholic » Wed Mar 10, 2010 4:30 pm
theres a difference between a standard factory ECU and a tuned factory ECU though isint there...
Postby MAGN1T » Thu Mar 11, 2010 11:41 am
All you need it too much timing advance. That'll make anything detonate with boost.
Knocklinks work well, flashing lights.
Steve
MAGN1T
Postby Burning Angel » Thu Mar 11, 2010 11:55 am
Steve
this.
you dont need an aftermarket ecu on most nissans,for example, with the right software and a tuning cable you can tune them just like you would a link ecu.
the local tuner has a R32 GTR running over 1100hp on a factory RB26 ecu
http://www.youtube.com/watch?v=rBZJFHtUcbs
pity the driver cant seem to get it to run good times.
on the other hand a toyota ecu can be reflashed, but not tuned on the fly making it pretty much useless
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby Mr Revhead » Thu Mar 11, 2010 11:56 am
How do you reflash a toyota ecu?
Postby Adamal » Thu Mar 11, 2010 12:04 pm
Are Toyota ECU's EEPROM?
Postby edwagon » Thu Mar 11, 2010 12:28 pm
To 'chip' Toyota ecus and some Nissan (sr20), they need to have Daughterboards added, and then jumpers changed on the original ecu so that it talks to the Daughterboard.
I had a very good custom tune done on an sr20 using a daughterboard, and have had a Mines ecu in a jzz30 which I opened up and had a look at.
Unfortunately the daughterboards are usually pretty expensive as a singleton purchase, and then to install (often multilayer ecu boards) and tune, makes them close to as expensive as an aftermarket ecu, which has the advantage of being a known quantity, and can be tuned by any old workshop.
edwagon
Postby tsoob » Thu Mar 11, 2010 12:41 pm
link g4 FTW
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby B_giB » Thu Mar 11, 2010 12:54 pm
tsoob wrote:link g4 FTW
Is that when its wired inand running? :lol:
Current: SXE10 Altezza
Previous:AE86 Trueno Notch Back: Gone but not forgotten :cry: :(
AE101 Levin 20V super strut
1994 Mercedes Benz C280 Sport
B_giB
Postby JustinSpiderholden » Thu Mar 11, 2010 2:39 pm
Steve
this.
But if the returned factory ecus were so good, why arn't all the top racing teams using them, how come most race cars I look into have a Motec?
JustinSpiderholden
Postby Burning Angel » Thu Mar 11, 2010 2:50 pm
well i spose to be more specific, a road car doesnt generally need all the extra features that an aftermarket ecu offers, like launch control, gear selectable boost control, datalogging etc.
im a big fan of aftermarket ecus, but for say a skyline roadcar i don't see the point spending all the extra money for an ecu with extra features you dont need/wont use.
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby tsoob » Thu Mar 11, 2010 4:00 pm
on the way to the dyno in about an hour 8) 8)
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby JustinSpiderholden » Thu Mar 11, 2010 5:40 pm
Kent or Tricky?
JustinSpiderholden
