ae86 clutch master cylinder
Postby ke_25 » Sun Mar 14, 2010 5:52 pm
Hey,
just put my 20v into my ke35, which is running a clutch master cylinder from an ae86, and the plenum is hitting, JUST! does anyone know of any master cylinders whcih are the same botl apttern etc but maybe slightly shorter? or even a smaller variant of an aftermarket option?
the current one is a silverline form repco
Cheers Shaun
PRESENT: KE35 Sr coupe (4agte project), GTS-T, MX40 Cressida coupe
EX:KE25 SL Coupe, KE30 4 door, KP61 4 door hatch, KE36 2 Door Wagon, AE70 2 Door Sedan, AE101 FXGT
ke_25
Postby frost » Sun Mar 14, 2010 6:28 pm
where is it hitting? the plastic tank or the mental body? on the master that is.
Postby ke_25 » Sun Mar 14, 2010 8:06 pm
the metal body, JUST. the piece which extrudes out the end about 10mm or so.
ke_25
Postby d1 mule » Sun Mar 14, 2010 8:42 pm
big hammer. sorted.
d1 mule
Postby frost » Sun Mar 14, 2010 9:24 pm
if your very VERY careful and do it in short bursts so not to heat up the master too much, you can grind away about 3mm safely
and give the plenum a scrape as well.
