3sgte st205 starter
3sgte st205 starter
Postby ihavelift » Thu Mar 18, 2010 11:05 am
So I got a gen 2 mr2 3sgte starter to replace mine, and it's far too big.
I replaced the solenoid with brand new ones in my current motor, carbon bush seems fine, a day later i was back to whacking it to get it to work.
I cannot be bothered $&#$% around with temp solutions, so does anybody (ants_555? Frank? ANYBODY??) have a st205 starter motor in good condition or know where I can get either a brand new OEM one or one that can replace the current one?
As this is my daily driver this needs to be fixed ASAP so please PLEASE help!
Nick - 021856524
Current: 2000 Honda Accord Wagon CF6
Previous: 97 Toyota Celica GT4 ST205; 2001 Toyota Allex RS180, 96 Nissan Sentra SG
Low, Slow, Clean and Mean
ihavelift
Postby RunningRich » Thu Mar 18, 2010 1:15 pm
Check the cranking voltage you get at the solenoid first. Excessive voltage drop over the wiring is not unknown. I had to install an additional relay in my ST165.
Richard
http://gtfour.supras.org.nz
RunningRich
Postby Akane » Thu Mar 18, 2010 1:15 pm
Do you have a MR2 crank pulley?
Postby ihavelift » Thu Mar 18, 2010 5:17 pm
cranking voltage? when it was removed the mechanic hooked it up to one of those mobile car starter battery pack things and checked it on 2 different points and it worked sweet, but a day after he put it back in after replacing the solenoids and the plunger it $&#$% out again and now it's hardly ever starting unless i whack on it for ages.
and no i don't have an mr2 crank pulley, what difference will that make? the mr2 starter won't even fit in the engine bay..
FUUUUUCKing annoying ... apparently a brand new one will be $1000+ so obviously not shelling out for that, does NOBODY have a starter around that I could buy?
ihavelift
Postby sergei » Thu Mar 18, 2010 5:47 pm
ihavelift wrote:cranking voltage? when it was removed the mechanic hooked it up to one of those mobile car starter battery pack things and checked it on 2 different points and it worked sweet, but a day after he put it back in after replacing the solenoids and the plunger it $&#$% out again and now it's hardly ever starting unless i whack on it for ages.
Here is the thing: if you have to whack it, it is mostly the contact surface inside of the solenoid is stuffed.
What I did on my ST165 (it would pull in but not rotate), I pulled the solenoid apart and polished/sanded the contact surfaces (also lubricate the rod while you there). There will be 3 surfaces: each side of the solenoid, and the disk that bridges them. After that it cranks every time.
Postby sergei » Thu Mar 18, 2010 5:50 pm
What did he replace the solenoid parts with? Brand new or from another second hand unit? The parts are very simple, and have high tolerances. The only reason why it would not work is that it is oxidised heavily or not pulling in completely due to sticking of the "plunger".
Postby ihavelift » Thu Mar 18, 2010 6:01 pm
he replaced it with brand new solenoid parts. so you think sand the contact parts and lubricate the rod (hahahaha oh dear)? ok I'm taking it back and refusing to pay until he $&#$% fixes it.
ihavelift
Postby RunningRich » Thu Mar 18, 2010 8:32 pm
Nothing to do with the starter itself. Check to see what voltage the solenoid actually sees when you are cranking. The Toyota starter wiring route was designed by a pissed village idiot and deteoriates easily, meaning the starter may only see 5-6VDC. This isn't enough to slam the solenoid enough (or even click).
This is enough however to drive a relay of fresh 12VDC direct from the battery.
The ST205 wiring is much better than my old cooked ST165 but I've seen this on a camry too.
Richard
RunningRich
Postby RunningRich » Thu Mar 18, 2010 8:33 pm
Forgot to say I found this out after rebuilding the solenoid at significant cost. Feking unique GT-Four parts...
Richard
RunningRich
Postby ihavelift » Mon Mar 29, 2010 6:41 pm
it IS clicking though, and the solenoid parts are all brand new, and the carbon bush looks perfectly fine (apparently).
Honestly I have no idea what it is - I turn the key, it goes CLICK but doesn't fire.
Can ANYBODY shed some light or give me some suggestions?
I can't afford $1000+ for a new starter, can I get an aftermarket from somewhere that is compatible with my st205? I'm at a loss eh, this is making me hate my car and want to smash it with an axe.
ihavelift
Postby ®usty » Mon Mar 29, 2010 8:50 pm
umm flat battery maybe??
®usty
Postby mr30%jr » Mon Mar 29, 2010 9:22 pm
RunningRich wrote:Check the cranking voltage you get at the solenoid first. Excessive voltage drop over the wiring is not unknown. I had to install an additional relay in my ST165.
it wasnt a grey one that got on sold?
3s starters are natorious for not spinning if they dont have enough juice to slap the solenoid across
mr30%jr
Postby ihavelift » Mon Mar 29, 2010 11:50 pm
no not a flat battery. and i will check the cranking voltage. hopefully that will fix it.
ihavelift
Postby ihavelift » Mon Mar 29, 2010 11:52 pm
would an st185 starter be a straight swap into an st205?
ihavelift
Postby Boosted_162 » Tue Mar 30, 2010 6:18 pm
ihavelift wrote:would an st185 starter be a straight swap into an st205?
Ive swapped starters between both my MR2 (gen 3) and ST185, and they look pretty much exactly the same.
Try talking to Japanese Spares for a ST205 starter, i got my ST205 motor from there and didnt get the starter with it.
Postby RunningRich » Tue Mar 30, 2010 8:45 pm
ihavelift wrote:it IS clicking though, and the solenoid parts are all brand new
Been there, done that, means nothing.
ihavelift wrote:Honestly I have no idea what it is - I turn the key, it goes CLICK but doesn't fire.
As stated, check the voltage the solenoid sees when cranking! :roll: Sounds exactly like the issues my ST165 had.
Another thing to do it put it in gear (ignition off) and push the car forward a foot or so. Then try starting it again. If it starts this supports the theory that the olenoid isn't being plunged out with aenough force to engage the copper contacts.
Richard
RunningRich
Postby ihavelift » Tue Apr 06, 2010 11:52 am
so to get this cranking voltage checked i guess i would take it to an auto electrician? or would a mechanic do?
and if it needs a relay - as yours did - how much would this cost (approx) and how long would i expect for it to take?
ihavelift
Postby ihavelift » Tue Apr 06, 2010 1:01 pm
RunningRich wrote:Another thing to do it put it in gear (ignition off) and push the car forward a foot or so. Then try starting it again. If it starts this supports the theory that the olenoid isn't being plunged out with aenough force to engage the copper contacts.
just took it out for a ride (roll started down my driveway) - still runs mint thank god. When I got back home i turned the car off then tried restarting only to hear click click again. does this mean anything?
either way, once i know whether to take it to an autoelectrician or a mechanic i will be going there and getting this $&#$% thing sorted
ihavelift
Postby RunningRich » Tue Apr 06, 2010 3:25 pm
Got a multimeter that measures voltage? Easy enough to put the lead on the solenoid terminal and read the display while someone cranks. Sparky would be best bet, should be able to install relay in less than an hour.
Richard
RunningRich
Postby ihavelift » Tue Apr 06, 2010 4:04 pm
cool, thanks richard
ihavelift
