oil flow 4age
oil flow 4age
Postby d1 mule » Thu Mar 18, 2010 7:50 pm
quick question,
does the oil flow out the center where the oil filter screws on or out the outside??
reason being just had my engine rebuilt due to run as bearings so dont want it to happen again :oops:
d1 mule
Postby tsoob » Thu Mar 18, 2010 7:52 pm
had the same problem, from memory it goes back in the center.
best way is to set it up and use the oil pump to pump it thru your lines with the coils off till it comes thru.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby d1 mule » Thu Mar 18, 2010 7:54 pm
thoght about that but do all the bearings etc get lubed then the oil gets filtered?? cuz if not they will be dry and run again??
thanks :D
d1 mule
Postby Burning Angel » Thu Mar 18, 2010 8:06 pm
oil gets filtered before going to anything else.
you could prime it if your really worried
but if its been properly rebuilt it'll have lube on all the bearing surfaces already.
another thing to do is unplug the injectors and crank it till you have oil pressure. then plug them in and away you go
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby KinLoud » Thu Mar 18, 2010 8:56 pm
oil flows from the oil pump to the outer part of the filter and then back into the block from the centre of the filter
Postby tsoob » Thu Mar 18, 2010 9:07 pm
i always crank over with out plugs to make sure oil pressure is up regardless.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby d1 mule » Thu Mar 18, 2010 11:04 pm
sweet thanks guys
d1 mule
