ae111 bt runing lean
Postby 96bzg » Fri Mar 19, 2010 4:46 pm
has any one else had this problem the cars at the machinics at the moment guy rung b 4 and even he was slightly stumpd by what was hapning from about 2500 to 4000 it bogs / stutters then once its over that it takes off i have a new oxy sensor new leads new spark plugs new fuel filter
96bzg
Postby Rick » Fri Mar 19, 2010 4:55 pm
SEARCH!! It seems to be a common problem.
Postby 96bzg » Fri Mar 19, 2010 5:22 pm
have just read all 8 pages of info, my car does it when warm and cold ... runs on 98 also
96bzg
Postby Rick » Fri Mar 19, 2010 5:43 pm
Are you assuming its running lean or have you tested it?
Postby 96bzg » Fri Mar 19, 2010 6:15 pm
tested dianostics and that came up it was running lean and machinic said it was also they are guna put fuel reg on it to check fuel pump tomorow
96bzg
Postby celica_xr9145 » Fri Mar 19, 2010 7:53 pm
Have you checked the condition of the fuel injectors?
celica_xr9145
Postby Bling » Sun Mar 21, 2010 1:36 am
Why are you driving it in such low revs? Blacktops run best 5-8k :wink: 8)
Postby 96bzg » Sun Mar 21, 2010 5:28 pm
car is at the machinics is going to ring me on monday...
hahaha yea but you gota go past 3 to get to 5 and makes it a nitemare to get there and dodge as to drive pulling out of intersections and it starts splutering as other car gets closer !
96bzg
Postby Stott69 » Sun Mar 21, 2010 6:16 pm
Have read that some one fixed it by checking and replacing a few caps in the ecu? Mine bogs a little, but no spluttering.
Image jzs147 Aristo money pit
Stott69
Postby Boost_4_Life » Mon Mar 22, 2010 11:34 am
yup, just fixed my silvertop by changing ecu
The rally beast
The rally beast again!
Boost_4_Life
Postby 96bzg » Mon Mar 22, 2010 2:26 pm
hmm may try to get second hand ecu and see if that makes a difference any idea price for one ?
96bzg
Postby 1I1 » Mon Mar 22, 2010 3:07 pm
TRD Clicky >>Here
1I1
Postby 96bzg » Mon Mar 22, 2010 5:23 pm
funy guy ae mark ... well fuel pump is fine now reakons its injectors or ecu ... have sourced a ecu to borrow to check this
96bzg
Postby .:O4AGTZ:. » Wed Mar 24, 2010 9:05 am
common problem on silvertops (and ae101 4agze) is that the capacitors tend to melt in the ecu. In your example those are the exact symptoms I experienced before replacing caps in a silvertop. Basically it messes with itself. You may get codes coming up but they could mean sweet f all as the computer is confused.
In 4agze they tend to jump into limp mode when this happens. Supercharger turns off, cant rev past 4g.
.:O4AGTZ:.
Postby 96bzg » Wed Mar 24, 2010 11:26 am
preaty gutard they didnt even work on car yesterday to try ecu or injectors. it only seems to run crap round 2500- 4000 then its ok im hoping it is ecu then prob upgrade to microsquirt one n get it tuned
96bzg
Postby 96bzg » Tue Apr 06, 2010 12:19 pm
ok in the weekend did work on the car replaced fuel pump swapd injectors spark plugs knock sensor tps and adjustd cleand throtle bodies swapd coil dizy cap and rotor leads checkd earths and oxy still stuters / misses goes beter tho ......
96bzg
Postby Flannelman » Tue Apr 06, 2010 2:15 pm
what about the fuel filter?
Flannelman
formerly known as Affroman
Postby 1I1 » Tue Apr 06, 2010 5:51 pm
Affroman wrote:what about the fuel filter?
That's been changed
TRD Clicky >>Here
1I1
