The optimum cure to this whole problem is to correct the exhaust firing cycle. The two cylinders that fire in succession into each collector have to be separated. This can be done partially by a "Tri-Y" header, where the four primary tubes from each bank merge into two secondary tubes (separating the two pulses firing in succession) and finally collect into a single collector. This type of header helps, but the two pulses are still coming back together at the collector.
The second optimum cure is to cross the two center tubes from each bank, across the engine running them into the collector on the opposite side. This makes the firing cycle in each collector 180 degrees apart, the same as a four cylinder engine. Once this firing order is achieved, the small collector outlet diameter can be used and the "High Velocity Scavenging" at low R.P.M.s cures the reversion problems and eliminates the need for extreme cam duration.
touge_ae101 wrote:there has got a better article on google somewhere that relates to 4 cyl engines and is very helpful.![]()
evil_si wrote:i normally do my 4 cyl twin scroll manifolds in firing order,
1 & 3 together and 2 & 4
Bazda wrote:1-4 & 2-3 on a 4 cylinder.
So you get a pulse into each scroll sequentially.
If you do 1-3, 2-4 you will get 2 pulses into 1 side of the scroll at a time.
Therefore not efficient and will increase the spool time.
So many times i've seen people make them like this and wonder why they dont get good spool running the twinscroll turbos with big a/r's.
Look at all the full race manifolds made for the honda guys they are 1-4 & 2-3.
XSVWGN wrote:Bazda wrote:1-4 & 2-3 on a 4 cylinder.
hmm well given that simon (evil_si) built my manifold the way he does i should expect average spool ...
Matt
