brake question - AE111 corolla
Postby eskimo » Tue Mar 23, 2010 8:02 am
Hi, simple question but I cant seem to find any clear answers on it.
Im changing the rotors and pads on my AE111 this weekend and want to know if i need to bleed the brakes while doing so or if i can just remove the cap on the reservoir and slowly push the piston back into the caliper
Will this effect the ABS or should I undo the bleed valve on the caliper then push the piston back in & bleed the brakes once the new pads and rotors have been fitted
"If in doubt, flat out" Colin McRae 1968-2007
Current:2003 Legacy 3.0R Spec B
Previous: ST185 GT4, SW20 MR2, ST206 Curren, AE111 Corolla GT
eskimo
Postby bluemaumau » Tue Mar 23, 2010 8:41 am
the rears 'screw' in if they are the same as ae101/92 fyi
Postby B_giB » Tue Mar 23, 2010 9:12 am
You can just remove the cap and push/screw in the piston.
Would pay to bleed brakes as you dont know how old the fluid is in there.
Just make sure if you do bleed the system to start with the one furtherest away from the master cylinder and move to closest to master cylinder with ABS equipped vehicles i.e RR-LR-LF-RF
Current: SXE10 Altezza
Previous:AE86 Trueno Notch Back: Gone but not forgotten :cry: :(
AE101 Levin 20V super strut
1994 Mercedes Benz C280 Sport
B_giB
Postby eskimo » Tue Mar 23, 2010 1:07 pm
Cheers, and its the front im changing. The rears are sweet, the pads that are in(EBC) it have just eat'n the rotors
The fluid isnt that old, less than a year from the receipts I have on the vehicle...still nice and clean/gold in colour.
eskimo
Postby Bling » Tue Mar 23, 2010 6:42 pm
I'd just loosen the bleed nut on the caliper just enough that it starts to weep out. Then take it all off, push the piston in, slap in the new parts then tighten up the bleed nut. I never touched the cap on the reservoir during install, just bleed as per normal then top up required amount into the reservoir. That's how i've done it anyway, seems to work :)
Postby eskimo » Tue Mar 23, 2010 10:32 pm
Yea thats what I was thinking. Will get stuck into it Friday once my rotors have arrived
Cheers JH
eskimo
