Recommendations 4AGE Smallport AE92 Hatch Back Exhaust
Postby gepsk8 » Wed Mar 24, 2010 1:40 pm
k, well i going to rebuilt my engine(standard)
and the car need need exhaust (religions) and going to change header (20valve header wont work, hits starter)
people idea's and what works and doesn't
i want quiet but good flowing exhaust
Size?
mufflers?
anyone could weld it up as perky in lower north island
O272754663
gepsk8
Postby Truenotch » Wed Mar 24, 2010 6:40 pm
20v blacktop extractors. Get a second flange made up to space them away from the starter and run a gasket between each. Then pull the studs and replace with either TVIS intake manifold studs (they're longer) or just long bolts.
2-1/4" from the collector back.
The best muffler I ever had was from my HKS AW11 exhaust. It would be similar to most baffled straight through mufflers.
This style is good:
Or the same style with the inlet and outlet offset from eachother with a small chamber in the middle.
Couple that with a Fluted coby before the muffler and you should have a good sounding, free flowing exhaust that you can live with.
Truenotch
Postby ChaosAD » Wed Mar 24, 2010 7:22 pm
if you havent already dropped the engine in you could move the starter to the intake side
ChaosAD
Postby gepsk8 » Thu Mar 25, 2010 9:22 am
ChaosAD wrote:if you havent already dropped the engine in you could move the starter to the intake side
looked at that when we did clutch, to much to muck around, spacing header out sounds good, nice and easy
O272754663
gepsk8
Postby gepsk8 » Tue Apr 06, 2010 11:33 am
O272754663
gepsk8
