There is a visible leak from between the master cylinder and brake booster.
Is this a sign of a faulty master cylinder? or just a case of needing to replace the paper gasket?
Dell'Orto wrote:Yup seals gone on the M/C. Quickly wipe it off before you go for a WOF
.Malcolm wrote:the only way fluid could really be able to get there would be if it's leaking past the master cylinder piston's o-rings - fortunately they're a piece of cake to rebuild if you get a seal kit for it...
