noisy cambelt
noisy cambelt
Postby eskimo » Mon Apr 05, 2010 2:45 pm
Hey,
Not a Toyota question but thought id ask any way.
Just jumped into my missus 91 323 to shoot up the road and when i started it It started making rather alarming tapping noise..sort of like noisy lifters but not as fast or metalic, The noise was coming from the cambelt end of the motor.
If you lift the revs to about 1500-2000 it stops then will start as soon as it drops to idle
The cambelt was replaced approx 80k ago so was due to be replaced in the next few weeks so I am assuming its a loose cambelt/faulty tensioner
I will pull the cover off later tonight and check the belt but is there anything else I should be looking at?
The motor is the 1600 twin cam(B6 I think)
JH
"If in doubt, flat out" Colin McRae 1968-2007
Current:2003 Legacy 3.0R Spec B
Previous: ST185 GT4, SW20 MR2, ST206 Curren, AE111 Corolla GT
eskimo
Postby ee904age » Mon Apr 05, 2010 3:44 pm
Funny you should mention it, my missus has a 94 323, which has developed a similar sound over the last couple of weeks. Ive traced it back to the A/C compressor as there is a slight bit of play is the shaft. I just need to take the time to ditch the A/C by putting a shorter belt on and just running it on the power steering pump.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby eskimo » Mon Apr 05, 2010 3:50 pm
Sweet, will check that as well. She doesnt A/C... mainly as it needs to be re-gassed so can bypass it if need be.
eskimo
