Crown Majesta ECU pin-out diagram.
Postby Quint » Tue Apr 06, 2010 1:38 pm
After a ECU pin-out diagram for a Crown Majesta ECU, if anyone can help it'd be awesome.
Quint
Postby FLAWLES » Tue Apr 06, 2010 1:56 pm
chassis and engine code might be of help aye
FLAWLES
Postby Quint » Tue Apr 06, 2010 3:04 pm
heh. Probably would be.
1991 - 1992 Toyota Crown Majesta with the 1UZFE.
Quint
Postby Quint » Wed Apr 07, 2010 12:39 pm
Found a wiring diagram for the LS400, which seems to be what my 1UZ is from. Also found 3x40p pinout for an ECU which is supposed to be the same (similiar) to the majesta ecu, so hopefully have it sorted.
If anyone needs the information I can send you the pdfs.
Quint
