PCV Valve idea's
PCV Valve idea's
Postby cat007 » Tue Apr 06, 2010 6:16 pm
Hey all
One of the items needing attention in my Supra is the PCV setup.
I was using a one way valve off a Pajero I think, but it was 2nd hand and isn't sealing properly so I want a new one (plus it was a little small).
Any suggestions where to get a decent flowing one way valve that wont be affected by oil/fuel etc?
Hunt
Postby sergei » Tue Apr 06, 2010 7:14 pm
PCV valve is not one way valve.
The purpose of the PCV valve is to regulate flow of blow-by and prevent from inlet "backfires" to pressurise the crank case (and blow out seals).
http://autoshop101.com/forms/h63.pdf
Postby mjrstar » Tue Apr 06, 2010 7:27 pm
Might be best to get one from a turbo's car like an evo or something I doubt the Paj one will be loving the boost.
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby cat007 » Wed Apr 07, 2010 7:56 am
mjrstar wrote:Might be best to get one from a turbo's car like an evo or something I doubt the Paj one will be loving the boost.
I wouldve thought a backfire in the intake manifold would have the valve see more pressure than what my turbo can pump out...
