Modifying Bumpers
Modifying Bumpers
Postby Emperor » Wed Apr 07, 2010 9:12 pm
Not Toyota, but a general question really.
Has anyone tried to DIY modify their bumper with good results?
I'm looking for a kit for my Stagea, but nothing locally available and cost and arm and a leg overseas, so wana buy something for a different car and modify to fit.
I guess the way to do it would be to cut the bottom of the new one and the top of the factory and join? But how to do it easiest and tidiest with plastic/fibreglass joining?
Emperor
Postby touge_ae101 » Wed Apr 07, 2010 9:22 pm
looked at getting mine lowered a while ago.
the best option i came up with was getting it plastic welded. plastic welding is real cheap and normally you can get smashed up bumpers for free with the lines/sections you want to add.
got quoted like 300bux for lowering the lip 100mm on ae101 trueno front bumper. that is all primered ready for paint.
not quite DIY but still on the cheap side
touge_ae101
Postby Emperor » Wed Apr 07, 2010 9:33 pm
Yeh, but you cant plastic weld plastic to fibrelgass.
Im talking about getting a URAS/BN Sports glass kit, and sticking it to my factory plastic kit
Emperor
Postby eskimo » Wed Apr 07, 2010 9:39 pm
You should be able to bond them together without to much hassle provided you use an epoxy resin or something as the fiber glass wont stick to plastic
"If in doubt, flat out" Colin McRae 1968-2007
Current:2003 Legacy 3.0R Spec B
Previous: ST185 GT4, SW20 MR2, ST206 Curren, AE111 Corolla GT
eskimo
Postby frost » Wed Apr 07, 2010 9:43 pm
convert to r34 front 8)
Postby evil_si » Wed Apr 07, 2010 9:44 pm
ive done it a few times,
had success modifying plastic bumpers and plastic welding them,
have also done a bit with fibreglass,
took a mould off the top of a factory bumper and then trimmed it to size and glassed a completely different fiberglass lower half to it
joining plastic and fiberglass can also be done but its a lot of work,
bracing and over lapping the join etc so it wont crack
evil_si
Postby eskimo » Wed Apr 07, 2010 9:44 pm
frost wrote:convert to r34 front 8)
Now thats a better idea..awesome conversion
eskimo
Postby frost » Wed Apr 07, 2010 9:45 pm
better to find a lower plastic lip that's close and get it plastic welded/shaped to fit,
finding a glue/resin that wont react to both plastic and glass is hard/expensive,
Postby Emperor » Wed Apr 07, 2010 10:55 pm
Nah, if was gona convert, would be R35 front... R34 square front would look ugly on a rounded M35... Older Stagea yeah. lol
Sweet, i'll try find a factory kit of somesort that I like, might be easier with plastic on plastic
Emperor
Postby frost » Wed Apr 07, 2010 11:31 pm
oh its the newer stag, yeah your right it would look funny,
if you find bumpers with the same abs plastic, the welding/bonding will be much easier. a friend even does plastic welding with a spade attachment to his soldering iron,
Postby rollaholic » Thu Apr 08, 2010 8:36 am
R35 front ftw then?
wonder how much those panels would cost... :lol:
Postby Emperor » Thu Apr 08, 2010 11:00 am
rollaholic wrote:R35 front ftw then?
A shitload i'd say.. Headlights alone would cost half my cars worth
Emperor
Postby Dell'Orto » Thu Apr 08, 2010 6:43 pm
Nah $&#$% that, go R30 Tekamen front, would suit the Stagea lines :lol:
Postby neo » Fri Apr 09, 2010 1:15 pm
careful with grafting fibreglass to plastic bumpers, its always the join that gives way..
If I was to do it again, Id cast a mould from the factory bumper and work from there
neo
