Removing aicon pump on AE101 4agze
Postby mr30%jr » Fri Apr 09, 2010 10:58 am
anyone done it and got pics of how they modfied the powersteering, can i ditch the powersteering?!
let me know
ditch the supercharger turbo it and run a 16v setup with alternator on the right right side?
mr30%jr
Postby Bazda » Fri Apr 09, 2010 11:42 am
You will need to use the PS off a normal 4age.
So you will need the following off any 4age 16v or 20v.
PS pump
Ps bracket
Bracket that holds the a/c pump
And the jockey wheel which is the tensioner.
Possibly the main PS line as the 4agze one is angled different and will not bolt up to a 4age.
Then you will need a 4age alternator and bracket with jockey wheel. Also the top adjustment bracket as well.
You can use the stock 4agze one but will need to fabricate to bolt the jockey wheel in a diff location
No PS in a turbo fwd car is insane.
Postby gleem » Sat Apr 10, 2010 9:09 am
i put a 20v on my 4agze and worked good. the pulleys are way bigger than 16v ones
gleem
Postby mr30%jr » Sat Apr 10, 2010 10:05 am
thanks baz i have a blacktop power steering pump sure i should be able to rig something up, its just all messy with the AC compressor there.
mr30%jr
Postby Quirky » Sat Apr 10, 2010 6:04 pm
heh, i paid $800 to have the airconditioning put back in.
Although Ausland is unbearable without the a/c
Hello There
Quirky
Postby mr30%jr » Sat Apr 10, 2010 7:29 pm
maybe in my daily but its got aircon just degassed
mr30%jr
