4agze water inlet pipe.
Postby Quirky » Mon Apr 12, 2010 4:34 am
Driving on Saturday night *crack* steam and water pissing out.
Turns out the water pipe has cracked.
Ive gone through TOYODIY:
Engine is a ae92 map sensored 4agze and that inlet pipe looks different to the one I have?
Maybe I am looking at it wrong but is this the right water pipe?
Any hints on the best way to replace it?
Hello There
Quirky
Postby mr30%jr » Mon Apr 12, 2010 8:58 am
normal 16v water pipe found on all 4ages in FWD
:wink: its strange for it to crack? didnt blow the seal against the waterpump?
oh and PS to get this off on my aw11 yesterday i had to remove the intake TB and supercharger....
good luck :wink:
mr30%jr
Postby Bazda » Mon Apr 12, 2010 10:22 am
4agze ones are different to 4age ones.
Postby sergei » Mon Apr 12, 2010 10:47 am
I believe I have an AE101 GZE pipe laying around. I will have to double check if it is there.
Postby mr30%jr » Mon Apr 12, 2010 10:52 am
not on AW11 EXACTLY the same part number. even on a FWD corolla?
mr30%jr
Postby themaleman » Mon Apr 12, 2010 12:34 pm
like bazda said, thers a difference, if you use a 4age 1 ull need the matching block thingy it bolts onto on the cambelt side of the engine (part 16331)
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
themaleman
Postby mr30%jr » Mon Apr 12, 2010 1:43 pm
16331 has nothing to do with that pipe... it attaches to the back of the waterpump
mr30%jr
Postby Quirky » Mon Apr 12, 2010 5:13 pm
My 4agze is turbo now with the smallport intake manifold. Can these stay as they are?
Hello There
Quirky
Postby Quirky » Mon Apr 12, 2010 5:35 pm
ahh ok, the diagrams used on toyodiy are the same for all the 4ag. However they do list different part numbers. Thats all I needed.
Hello There
Quirky
Postby themaleman » Mon Apr 12, 2010 7:20 pm
my bad wrong pipe
4agte ae92 Levin
a15 powered sj410
themaleman
Postby Quirky » Tue Apr 13, 2010 2:08 am
Alright got the pipe out. Surprisingly easy, took about 10 mins.
There was a braket that was welded onto the pipe that broke. No screws on the original mount, weird.
Is this a 4agze water pipe? It looks different to the diagram in original post because it only has one bolt mounted to the water outlet thing.
Im not going to buy a new one, im gonna get a shop to weld over it.
Any problems with this idea?
New one is $140 from Japan...
Hello There
Quirky
Postby Quirky » Tue Apr 13, 2010 2:12 am
ohh woops my mistake, the pipe i highlighted in the original post is a different water pipe. its suppose to be the pipe above it....
Hello There
Quirky
Postby mr30%jr » Tue Apr 13, 2010 8:28 am
ahem...................................
yes. well THAT pipe is diferent thats the heater bypass hose.
mr30%jr
Postby Quirky » Tue Apr 13, 2010 12:27 pm
heater bypass aye?
Should be sweet to weld over it then?
Hello There
Quirky
Postby mr30%jr » Tue Apr 13, 2010 3:03 pm
NO lol no its not ok to weld it up....
what that does is feeds water around the head and block bypassing the the thermostat so the car can get warm, pump water around and get the heater warm too.
without that water would sit stationary in the head and block, boiling and rooting things , the thermostat would never open.
wats with the brack thats been welded ot it....
the hoes just hasnt cracked someones made it weak by welding to it then its ripped a chunk out.
mr30%jr
Postby Quirky » Tue Apr 13, 2010 5:02 pm
Apparently the original bolt screws to the supercharger? But because of the supercharger removed it doesn't bolt to anything...I think thats how the workshop explained it to me.
Hello There
Quirky
Postby themaleman » Tue Apr 13, 2010 6:25 pm
ahahahah so i was right! you can see the difference i was talking about in your pic, your 1 has the bolt bolting the pipe to the casting on the left side, where the pipe in the diagram has it on the right.
4agte ae92 Levin
a15 powered sj410
themaleman
Postby Quirky » Tue Apr 13, 2010 6:35 pm
Yea my mistake.
The workshop who built my car offered to fix it at no charge, so i dont have to worry about it.
Hello There
Quirky
Postby sark.inc » Tue Apr 13, 2010 8:39 pm
looks like a fair bit of corrosion on that pipe, you are running coolant right, not just plain water?
sark.inc
Postby Crucible » Tue Apr 13, 2010 9:20 pm
mr30%jr wrote:NO lol no its not ok to weld it up.
why not?, its only mild steel tube. Ive brazed a few coolant pipes in the past.
as long as its not corroded too badly, welding is definately an option.
Crucible
Real Life Mechanic
