What cam angle sensor is this? Mitsi Evo? VR4? Mirage?
Postby Bazda » Sat Apr 17, 2010 11:04 am
Ok, having troubles finding the correct cam angle sensor.
I got mine years ago now which I converted to fit into a ae111 20v head. It was off a mitsi eng with dual coils. I duno if it was a VR4, Evo, etc etc
This is what it looks like from the back for the one I want.
Front
The problem is I keep buying them but it comes with a diff tooth on the end of the shaft. The ones I keep getting the shaft is different so I cant do the modification to fit into the 20v head. I cant find a pic of the ones I keep getting but the tooth part isnt like a machined piece like the one int he picture above, its more of a pressed together piece of flat steel.
Anyone know what model car I need to get this CAS off?
Postby strx7 » Sat Apr 17, 2010 12:08 pm
the N33W type range of RVR's have 3 different cam angle sensor on them, it looks like one of the different types of them. dont suppose you have any numbers off it?
