Air box temp sensor
Air box temp sensor
Postby ST205 GT4 NZ New Group A » Mon Apr 19, 2010 4:23 pm
Hi just a general question on the relevance of the air temp sensor in the air box on a st205 3sgte.
Is it just for ambient air temp to the ecu or is there a comparison with the plenum air temp sensor, how does it figure in the equation ie what does the ecu do with this input and how does it affect tuning and the state of the engines operation.
Thanks
Last edited by ST205 GT4 NZ New Group A on Mon Apr 19, 2010 4:52 pm, edited 1 time in total.
Re: Air box temp sensor
Postby cat007 » Mon Apr 19, 2010 4:49 pm
ST205 GT4 NZ New Group A wrote:Hi just a general question on the relevance of the air temp sensor in the air box on a st205 3sgte.
Is it just for ambient air temp to the ecu or is there a comparison with the pentium air temp sensor, how does it figure in the equation ie what does the ecu do with this input and how does it affect tuning and the state of the engines operation.
Thanks
WOAH!!! you've got a pentium air temp sensor? That's hard core. Mines a dx66 486 at best!
yea baby
Postby ST205 GT4 NZ New Group A » Mon Apr 19, 2010 4:53 pm
spell check !
Postby matt dunn » Mon Apr 19, 2010 7:51 pm
Do they even have two IAT sensors?
normally there will only be one,
in the airbox,
in the AFM,
or in the plenium,
but usually only one.
Postby frost » Mon Apr 19, 2010 8:01 pm
st215 caldina has two aswel, i'd like to know this answer too,
Postby fivebob » Mon Apr 19, 2010 8:12 pm
I believe the airbox one is used to activate low boost mode when the ambient temp is too cold. Guess the easiest way to test that theory would be to replace it with a 5-10kOhm resistor and see what it does ;)
