bigport AFM 4agze improvements
Postby mr30%jr » Mon Apr 19, 2010 5:45 pm
I bought an aw11 S/C seems like the headgasket is poked, so i might tear it down as its done 195,000ks.
What improvements can i do to the engine while its out and apart.
Is it the norm to just rering it, do all the bearings, and clean everything up?
is it worth while shaving the head?
I generally want to keep it stock like on the intake side, exhaust could do with some headers
could posibly look at wacking tvis on it and a bigport intake and turbing it. want to run a max of 14psi. is a crusty old bigport with freshen up capable of reliably pulling this off? and what are fairly well suited turbos for this application
mr30%jr
Postby Mr Revhead » Mon Apr 19, 2010 7:27 pm
No idea on turbo, but if you keep it stock s/c some higher comp pistons from an N/A version works well. Or maybe a TRD stel head gasket to up the compression, you will have to check how much that will alter it though.
Water to air intercooler is a huge gain
Postby d1 mule » Mon Apr 19, 2010 8:29 pm
why would you put TVIS on it if you turboed it??
either the nissan T28 or the Ht18s-t3 combo are the pooular easy to get cheap turbos.
iv got a Ht18 T3 on mine all up it cost about $500 i think, but iv seen them for sale for $150
d1 mule
Postby mr30%jr » Mon Apr 19, 2010 9:28 pm
d1 mule wrote:why would you put TVIS on it if you turboed it??
because its been proven to be very effective on even a turbo even maybe make it open when the turbos at boost
ive heard of nissan turbos shitting out really easy hence i want reliablity
mr30%jr
Postby kompressor » Wed Apr 21, 2010 8:04 pm
new bearings, rings and a small port head
kompressor
Postby Bazda » Wed Apr 21, 2010 11:24 pm
If you keep the SC and stock ecu, id try keep the compression similar to stock. Add on a bigger pulley to run 14psi, better intercooler, using the n/a intake manifold would be an improvement as the stock one flows pretty bad i've heard. Ex manifolds - if you can fit fwd 4age 20v ones in that would work.
Turbo with stock ecu - I did this years ago and 10psi was the max until it ran too lean, this was using a T28 turbo. I just added in an extra injector with a link injector controller and switched that on at 10psi. That unit has a duty cycle gain control as well so was pretty easy to setup on the dyno.
Got me over 200kw atw on 20psi.
Postby Mr Revhead » Thu Apr 22, 2010 9:24 am
My AW11 had a bigport redtop longblock (so 9.4:1) running stock AW11 4agze ecu etc. ran fine, much faster than a stock one. Helped by C52 gearbox. Was running an indicated 8-9psi.
Postby mr30%jr » Thu Apr 22, 2010 10:48 am
still hanging in there. wedgie and that aw lol
mr30%jr
Postby Mr Revhead » Thu Apr 22, 2010 10:50 am
It has had a good long HARD life! :lol:
Postby mr30%jr » Thu Apr 22, 2010 10:51 am
kompressor wrote:new bearings, rings and a small port head
easy to say not easy to do :lol: smallport heads dont come up that offen wouldnt really be worth to be honest with force induction you better of with bluetop cams?
mr30%jr
Postby gepsk8 » Tue Apr 27, 2010 5:59 pm
who's motors you got in picture? looks good
O272754663
gepsk8
Postby mr30%jr » Wed Apr 28, 2010 5:56 pm
my ae86 4age,
silvertop block crank and rods
smallport pistons
largeport head mild port
8)
mr30%jr
Postby mr30%jr » Wed Apr 28, 2010 5:57 pm
my ae86 4age,
smallport pistons
8)
mr30%jr
Postby gepsk8 » Wed Apr 28, 2010 7:07 pm
nah. nah i meant the one you posted on first post with turbo on side of it
O272754663
gepsk8
Postby mr30%jr » Wed Apr 28, 2010 7:17 pm
yea looks ok i cant memba i just went to google and went 4agze turbo
mr30%jr
