Dash and tailights not going
Postby GT4-Addict » Sat Apr 24, 2010 8:38 pm
Hi everyone. I have just lost the dash and taillights on my st185 celica.
Im suspecting its the fuse, which i assume is down by the drivers foot? does anyone know which one im looking for or have a diagram of all the fuses?
Also, if its not the fuse does anyone have any ideas what else it could be? Relays etc?
Cheers! Sam
GT4-Addict
Postby Bling » Sat Apr 24, 2010 8:47 pm
Interior light working?
Postby Boosted_162 » Sat Apr 24, 2010 9:03 pm
Sounds like the dome fuse, which i think is under the bonnet by the battery? (havent looked at mine for a while :lol:)
Havent installed a headunit lately have you? :P
Postby Brick » Sat Apr 24, 2010 9:04 pm
It'll be a fuse, if you dont have a test light just pull out one at a time
Brick
I know Kung Fu
Postby Boosted_162 » Sat Apr 24, 2010 9:09 pm
Check the fuse below the arrow, labelled DOME 20A
Postby Alex B » Sat Apr 24, 2010 9:13 pm
Boosted_162 wrote:Havent installed a headunit lately have you? :P
box of chocy fish says yes.
Postby GT4-Addict » Sat Apr 24, 2010 10:12 pm
Nah i havent installed a headunit lateley, i dont really give 2 cents about sound systems in cars, just extra weight as far as i am concerned. Only work i have done recently is replace the steering rack boot and left tie rod end.
I didnt think to check the interior light. I will check the dome fuse tomorrow, fingers crossed it it blown! i had to jumpstart the car the other day, prehaps this had something to do with it........
GT4-Addict
Postby Boosted_162 » Sat Apr 24, 2010 10:21 pm
GT4-Addict wrote:Nah i havent installed a headunit lateley, i dont really give 2 cents about sound systems in cars, just extra weight as far as i am concerned. Only work i have done recently is replace the steering rack boot and left tie rod end.
The reason we ask about the radio, is that many many people install headunits, and use the illumination wire as a ground (its a brown wire iirc), and it acts like an earth till the lights are turned out, so blows the dome fuse affecting the taillights and dash lights :)
If you dont have the stock headunit in there (either aftermarket or nothing) check to make sure there is no wires shorting, as that could be causing it to blow the fuse. I infact did the same thing to my MR2 installing the backlight on my boost gauge, even tho i know about the illumination wire i still accidentally earthed it through that, and come wof time, i had no taillights :oops: :lol:
Postby GT4-Addict » Sun Apr 25, 2010 4:56 pm
I Just went out and checked the dome fuse, Its fine. Im thinking either a relay has gone kaput or i have a split/ shorting wire somewhere. Any ideas?
GT4-Addict
Postby rollaholic » Sun Apr 25, 2010 5:14 pm
choccy fish all round?
Postby Brick » Sun Apr 25, 2010 5:15 pm
check fuses by foot pedals
Brick
I know Kung Fu
Postby Alex B » Sun Apr 25, 2010 6:27 pm
Might have to be.
Postby matt dunn » Sun Apr 25, 2010 8:14 pm
Dome fuse?
that is constant power that feeds interior light, and clock and stereo memory?
Nothing to do with tail lights.
there will be a specific tail light fuse,
and it is in the interior fuse box.
Postby GT4-Addict » Fri Apr 30, 2010 1:40 pm
Problem solved. Turns out wires had come loose in behind the dash and were creating a short circut. Took a decent amount of time and swearing to figure it out!
GT4-Addict
