blacktop idling rough than stalling
Postby Cakky » Wed Apr 28, 2010 10:02 pm
Car has been playing up recently, car will idle away at about 1000rpm, then will slowly drop down every couple of seconds until it stalls. Have done diagnostic check and nothing flashed up.
My air filter is particularly dirty @ the mo, very dirty infact, will this be a cause of the problem? Or will it be something else? Cheers
1989 Corolla GT sedan blacktop 20v
Cakky
Postby ~SlideWays~ » Thu Apr 29, 2010 10:17 am
I had the same on a Silvertop and ended up taking the Idle Control Sensor jobbie out then spraying with carb cleaner, it came out black as black.
That fixed the problem for me.
Clean/replace the filter first though :wink:
EDIT: google ISCV - Idle Speed Control Valve
~SlideWays~
Postby 96bzg » Thu Apr 29, 2010 8:30 pm
cnt help you but my car has the same problem sits at about 1000 and drops down to 600 ish almost dies but them piks up again ive tryd another tps didnt make any diff
96bzg
Postby rollaholic » Fri Apr 30, 2010 8:38 am
follow slideways advice ^
Postby cat007 » Fri Apr 30, 2010 8:51 am
rollaholic wrote:follow slideways advice ^
+1
Those symptoms could also be that it's running lean, i.e. High revving for a little then dying? Not likely though
Postby 96bzg » Fri Apr 30, 2010 6:32 pm
hadnt been told to check that had quick look and found good link with all the info how to clean it, my car is runing lean also
96bzg
