20v black top issues
Postby eskimo » Wed Apr 28, 2010 11:52 pm
Ive been having a few issues with my AE111 corolla, they are being a pig to drive when cold... hesitation etc, and an odd miss at between 2500-3000rpm(a light jerk) when on light throttle
Ive searched the forum and come up with the following
-Check for fault codes
-clean the IBT's
-bung O2 sensor
-ignition, plugs leads etc
Ive got a bit of time on my hands this weekend and so hoping to track down what it is, is there anything else I should be looking at? Also in regards to checking for fault codes what are the two terminals i need to connect? TE1 & TE2...
Also have an issue with what I think is the release bearing, there is a rattle from the gearbox when the clutch is released & not under load. Goes away when I but the clutch in, could this be anything else?
Jordon
"If in doubt, flat out" Colin McRae 1968-2007
Current:2003 Legacy 3.0R Spec B
Previous: ST185 GT4, SW20 MR2, ST206 Curren, AE111 Corolla GT
eskimo
Postby mr30%jr » Thu Apr 29, 2010 3:24 am
i have the same problem but havent got round to fixing it,,, im pretty sure its the leaky cap problem...
mr30%jr
Postby ChaosAD » Thu Apr 29, 2010 8:17 am
ChaosAD
Postby eskimo » Thu Apr 29, 2010 8:58 am
Thanks, ive read that thread several times. Just wondering if there was anyone who found anything further on it.
Also in regards to the rattle from the gearbox, is that likly to be the released bearing?
Cheers JH
eskimo
Postby mr30%jr » Thu Apr 29, 2010 9:15 am
nah thats the input shaft bearing. check your gearbox oil they usually make a little bit of noise but not a rattle
mr30%jr
Postby eskimo » Thu Apr 29, 2010 11:02 am
Cheers, was going to check it tonight as the gearbox seems a little notchy sounds a bit dry so hoping its not really low. The rattle has been there a few weeks... i assumed it was the release bearing
Think ill drain it completly in the weekend and fill with new oil, any recomendations on the oil for the 6speed. I was going to go for a castrol syntrax 80-90(i think, could be 75-90) or valvalene dura gear 75-90
eskimo
Postby sergei » Thu Apr 29, 2010 11:03 am
eskimo wrote:Cheers, was going to check it tonight as the gearbox seems a little notchy sounds a bit dry so hoping its not really low. The rattle has been there a few weeks... i assumed it was the release bearing
Syntrax is the right oil for that gearbox (not sure about valvoline).
Postby eskimo » Thu Apr 29, 2010 1:47 pm
Cheers sergi
eskimo
Postby BigDon » Thu Apr 29, 2010 9:41 pm
Knock sensor is another common problem with similar symptoms.
www.europeandirect.co.nz
1996 AE111 BZ-G: TRD equipped road legal Club Car (Manfeild 1.25s) (SOLD)
1995 AE111 BZ-G: Stereo and daily driver (SOLD)
2005 NZ New Evo 9 GT (specd to FQ360) daily driver
2012 NZ New Outlander VRX - V6 family wagon
BigDon
Postby eskimo » Thu Apr 29, 2010 10:11 pm
Sweet, if its a bung knock sensor that would throw out fault code 52? when I link TE1 and E1(i think thats the two)
eskimo
Postby mr30%jr » Fri Apr 30, 2010 1:08 am
eskimo wrote:Sweet, if its a bung knock sensor that would throw out fault code 52? when I link TE1 and E1(i think thats the two)
deffinatly would throw a code...
this is why the capacitor issue is thought of becuase it doesnt throw codes... but a really dip before going closed loop...
mr30%jr
Postby eskimo » Thu May 06, 2010 8:53 am
Well sort of solved the problem, replaced the plugs and cleaned the itbs... and its a lot better than it was.. waiting on a my O2 sensor to arrive so will replace that once received
Also replaced my gearbox oil with castrol syntrax 75w-90(only cost me $15 per L...step dads work are castrol agents) and WOW what a difference good oil makes
eskimo
