MAGN1T wrote:Ahhhh, bought a lemon.
If the last owner had any clues they would have dropped a bottle of additive into the cooling system, that should hide most of the symptoms for the next 3 months or so.
I'd suspect that the gauge is reading wrong too. Try earthing the wire that pulls off the sensor, make sure the gauge creeps up to the red when you turn on the key.
Steve
tsoob wrote:MAGN1T wrote:Ahhhh, bought a lemon.
Steve
then change the headgasket
gleem wrote:ok. put a new tgp thermo stat in and now it gets up to tempreture but the top hose gets really hot and bottom hose not at all? at normally operating tempreture. half way. I know this shouldnt be right
