Who has shotpeened rods?
Postby Flannelman » Mon May 03, 2010 5:47 pm
Help needed with this
In the process of getting shotpeened, balanced silvertop conrods with ARP rodbolts. Pistions are standard, to be balanced as well. All were crack tested - pass.
Question is, what is the "safe" RPM limit of this combo? Im asking for people with experince with this set up or similar please.
Flannelman
formerly known as Affroman
Postby dnalunchie » Mon May 03, 2010 6:55 pm
I ran this same set up in my AE101 "OHHBOY" at 9000 rpm for many months, no problem.
Larger fuel pump, blacktop cams and link ECU whole engine had been balanced much the same as yours. The question really becomes how high do you NEED to rev it to get the power you want.
With my cams there really was no need to rev higher than 8500.
Current: 90 3sfe Corona
dnalunchie
Postby matt dunn » Mon May 03, 2010 7:02 pm
Standard rods good to 8700, shotpeened rods good to 9000?
I dont think that it makes that much difference myself when i did a lot of research into it.
Postby rx7guy » Mon May 03, 2010 7:44 pm
Shot peening increases the fatigue life which is related to the surface condition (cracks etc). As the surface is refinished during the process they should effectively act like new rods, just a wee bit stronger.
My theory anyway.. :roll:
The torque band is wide and the road is narrow
rx7guy
Postby Akane » Mon May 03, 2010 7:59 pm
I thought rev limit is more related to how strong your rod bolts are, while shot peening can increase the limit it'll fatique (ie: bent rods from repeatitive high power runs)
Postby iOnic » Mon May 03, 2010 8:35 pm
dnalunchie wrote:The question really becomes how high do you NEED to rev it to get the power you want.
+1. No point revving it higher if it isn't making any more power.
Postby frost » Tue May 04, 2010 12:05 am
for the price of getting all this work done, you better off paying another $150 for a set of h beams, (unless you have good hook ups)
i went through this debate about a year ago for my blacktop, had the rods all ready to go to ANZ, but the H rods are so cheap and SO much better its not a hard choice, look at spool or eagle, both at the same price of about $550 depending where you get them from, with arp bolts too,
Postby Brick » Tue May 04, 2010 12:09 am
i used ze rods on my old engine with arp bolts. Always saw 9000rpm and never had problem.
Mind you if your spending that much $$ on a engine to make power that power that high you may as well spend that wee bit more for decent rods as said above
Brick
I know Kung Fu
Postby matt dunn » Tue May 04, 2010 12:12 am
Brick wrote:i used ze rods on my old engine with arp bolts. Always saw 9000rpm and never had problem.
I used silvetop rods and new geniune toyota rod bolts at about $3 each on one of my old race motors.
Went for 2 years of hard racing in my car without trouble till I sold the engine.
Postby Flannelman » Tue May 04, 2010 5:41 pm
Its abit of an experiment at the moment.
Headflow numbers sugest power will be 9330. In theory at least. Was looking at 9500 limit.
Ive got connections for the work, and new rods suggest more rpm, so new forged pistons would be neeeded too. Costing $1000+ for only 500 more rpm till the oil pump is the issue...
Just testing stock parts, but trying not to build a silvertop hand grenade either.
More comments welcome on the subject
Flannelman
Postby Malcolm » Tue May 04, 2010 6:00 pm
I'm curious to know how you've correlated flow numbers for the head to an engine speed you expect to see peak power (especially to a precision of 10rpm).
The manifolds attached to the head will have a big effect on where you see the power, as will the cams and how they're timed. On top of that, frictional losses can really start to add up at high engine speeds which would tend to lower the speed where you see peak power.
Postby 4agtepwr » Tue May 04, 2010 11:13 pm
I spent a lot of time linishing the beams of my rods and balancing them so they were all spot on and then had them shotpeened, along with arp rod bolts they seem to be fine, makes power at 9 grand and has seen close to 10 at the drags, 420hp to so no light load. Having said that ive never seen a modern jap "performance engine" break a rod through out and out horsepower, its normally a rod bolt that lets go or due to a run bearing.
Current ride: Sweeeeet Hiace. 3L power!!!!
Project: AW11 4agte, 410kw 555hp on 26psi
11.1 @ 125.5mph with more to come, As seen in Aug 2011 Performance Car, haha
viewtopic.php?t=61383
Huge thanks to Phil from NZEFI, Al and Brendan from Caraid and Hamish from Sheifield Cresent Auto
4agtepwr
Postby Flannelman » Wed May 05, 2010 8:57 am
http://users.erols.com/srweiss/tablehdp.htm
Headflow ive got is 210cfm.
Cubic inch of 4age is 98. Close enough to 25 each cylinder. Connect the lines, find 9332 rpm. Doesnt tell me how much tho.
Use as a guide, not a rule.
4agtepwr, thank you. Very helpful
Flannelman
Postby QikStarlie » Thu May 06, 2010 7:59 pm
i use stock slivertop rods with arp bolts. 8900 limiter. and yeh it hits that EVERY time it gets driven.
QikStarlie
