I'm running coil over plug ignition in my ae92 levin gtz and the tacho isn't working.
Using 1zz-fe coilpacks.
Currently I'm just taking the IGF signal off each coilpack then all four wires are joint together and connected to the tacho wire. I'm assuming this will create a 5v square pattern (might be 12v haven't measured it yet).
Can anyone tell me what the gtz tacho is expecting to see? Voltage spikes or square wave, and how many volts?
Or have I done something fundamentally wrong here?
Cheers.
