Are forged pistons REALLY worth it?
Postby Adoom » Sun May 09, 2010 2:57 pm
So yeh, I had this thought. If an engine running high boost does not pink/detonate/knock, what is the point of running forged pistons?
I intend to rebuild a CA18DET I have, to replace the CA18ET currently in THE STARVIA.
I am tossing up whether or not I NEED forged pistons. I could buy a LINK for the price of a set of "forgies"!! 8O
I will be running water injection which reduces the risk of detonation by lots.
I want to be able to run decent boost with little risk of failure.
If little brother ~SlideWays~ can make 212kw with a 4AGTE..... where the $&#$% is my lots of Kw? :twisted:
Adoom
Postby matt dunn » Sun May 09, 2010 6:04 pm
it would depend on the quality of the std pistons.
Factory toyota GZE pistons are very good.
Postby iOnic » Sun May 09, 2010 6:24 pm
Forged pistons give you a bigger margin for error. If you're running right at the limit of what is safe for your engine, even something as simple as a slightly bad batch of fuel could introduce fatal detonation.
Postby Dell'Orto » Sun May 09, 2010 7:18 pm
Plus there is only so much a standard cast piston can take...though its usually quite a bit of HP.
Postby Adoom » Sun May 09, 2010 11:07 pm
matt dunn wrote:it would depend on the quality of the std pistons.
Doesn't the 4agze have forged pistons standard anyway?
Adoom
Postby Adoom » Sun May 09, 2010 11:08 pm
Dell'Orto wrote:Plus there is only so much a standard cast piston can take...though its usually quite a bit of HP.
Oh, thats okay then. I've been using Kw, no HP here! :lol:
Adoom
Postby Dell'Orto » Sun May 09, 2010 11:35 pm
Oh no thats worse, takes way less kw than hp to break them 8O
Postby ~SlideWays~ » Mon May 10, 2010 9:46 am
Get a 4age.
As far as I know SR20DET's and 4G63's aren't forged and with a good tune they all seem ok with 200kw's.
Does the CA18DET have oil squirters?
~SlideWays~
Postby iOnic » Mon May 10, 2010 9:56 am
CA18DET will make 200wkw on the stock internals with no drama. Silvia/Pulsar T28 with supporting mods will see you close to that. They're pretty beefy little engines. No need for water injection at that level unless it's being tuned by a muppet.
Yep CA18 has oil squirters and a crank girdle...and is built like a brick shithouse.
Postby Adoom » Mon May 10, 2010 1:44 pm
iOnic wrote:CA18DET will make 200wkw on the stock internals with no drama. Silvia/Pulsar T28 with supporting mods will see you close to that. They're pretty beefy little engines. No need for water injection at that level unless it's being tuned by a muppet.
Oil squirters = CHECK
Crank Girdle = NOPE
Early FWD CA18DET do not have the girdle. I have one of those.... But I have a girdle from another RWD CA18DET I had years ago, I should have kept the rest of it too.
Adoom
Postby iOnic » Mon May 10, 2010 2:25 pm
What is your CA out of? My old CA18DET in an 88 RNU12 Bluebird had a crank girdle and I'm pretty sure they're one of the first CA18DET's?
Postby Adoom » Mon May 10, 2010 5:57 pm
iOnic wrote:What is your CA out of? My old CA18DET in an 88 RNU12 Bluebird had a crank girdle and I'm pretty sure they're one of the first CA18DET's?
Not sure. I got it from an engine importers off trademe.
I think I read in a forum that some of the U11 Bluebirds had them.
Mine has a crossover inlet manifold rather than a reversed....$&#$% it.
It look like this http://carphotos.cardomain.com/ride_images/3/190/1301/25473150006_large.jpg
Adoom
Postby iOnic » Mon May 10, 2010 6:01 pm
Aah ok. Mine had a side fed intake mani...Is that yours in the picture? looks bloody clean 8O
http://img.photobucket.com/albums/v665/ ... 0012-2.jpg
Postby ~SlideWays~ » Tue May 11, 2010 10:14 am
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: Adoom with a 'clean' car :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
:lol:
*dies*
~SlideWays~
Postby Adoom » Tue May 11, 2010 11:07 am
iOnic wrote:Aah ok. Mine had a side fed intake mani...Is that yours in the picture? looks bloody clean 8O
Nah, its just a random picture I found. Mine is filthy.
Adoom
Postby 4agtepwr » Tue May 11, 2010 11:46 am
Id buy a link and pay for a decent tune way before I brought forged pistons,
Det will break a land on a forged piston as well as a cast one, it will just stand up to a shit tune a little longer, have seen over 500hp on standard sr20 pistons and ca one's will be fine. Buy a g4, get a decent tune and it will last way longer than a well built, but badly tuned forged motor
Current ride: Sweeeeet Hiace. 3L power!!!!
Project: AW11 4agte, 410kw 555hp on 26psi
11.1 @ 125.5mph with more to come, As seen in Aug 2011 Performance Car, haha
viewtopic.php?t=61383
Huge thanks to Phil from NZEFI, Al and Brendan from Caraid and Hamish from Sheifield Cresent Auto
4agtepwr
Postby Heylin » Tue May 11, 2010 1:13 pm
Det will break a land on a forged piston as well as a cast one, it will just stand up to a sh*t tune a little longer, have seen over 500hp on standard sr20 pistons and ca one's will be fine. Buy a g4, get a decent tune and it will last way longer than a well built, but badly tuned forged motor
Thats exactly what ive done, $220 for a full set of cast pistons and rings (NPR\Teikin) Brand.
Aiming for a safe tune and 200-220 RWKW
Heylin
Heylin
