st215 vr sensors
st215 vr sensors
Postby shellys » Wed May 12, 2010 7:58 pm
which is the signal and which is the earth for aftermarket ecu's the blue or the black or doesnt it matter
shellys
Postby fivebob » Wed May 12, 2010 8:09 pm
It matters because the -ve(B-W) wire is common between the two sensors.
Might I suggest you would get more replies if you didn't refer to them as VR sensors. Most people would have no idea that VR stands for Variable Reluctance (magnetic) and wonder why the ST215 uses Virtual Reality sensors ;)
Postby shellys » Wed May 12, 2010 8:20 pm
ok sorry, i am using a megasquirt with the black wires earthed, is this ok?
shellys
Postby fivebob » Wed May 12, 2010 9:49 pm
shellys wrote:ok sorry, i am using a megasquirt with the black wires earthed, is this ok?
That should work
