Rear knocking
Rear knocking
Postby eskimo » Wed May 12, 2010 9:57 pm
Hey,
I have slight knock coming from the rear when going in and out of driveways / small bumps etc in my AE111 corolla.
The car doesnt have a rear sway so could warn castor arm bushes's make a similar sound?
JH
"If in doubt, flat out" Colin McRae 1968-2007
Current:2003 Legacy 3.0R Spec B
Previous: ST185 GT4, SW20 MR2, ST206 Curren, AE111 Corolla GT
eskimo
Postby Mr Revhead » Wed May 12, 2010 10:43 pm
maybe...
also check shocks
top hats
and random things in the boot! yes! really! :lol:
Postby eskimo » Thu May 13, 2010 9:12 am
Sweet, will check the shocks and top hats tonight. The boot is empty... as that something rolling around was my first though
JH
eskimo
jack
Postby panda_dan » Thu May 13, 2010 9:57 am
I had a similar problem, drove me mad
Then I opened the rear compartment that holds the jack and tools and the jack was loose!
Tapping on the guard from the inside
panda_dan
Postby mjrstar » Thu May 13, 2010 10:35 am
I had this issue also, it turned out to be worn swaybar bushes.
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby eskimo » Thu May 13, 2010 1:46 pm
Yea, first thing i check was the jack, spare wheel..under the spare wheel. Doesnt have a rear sway bar..yet 8)
Was thinking maybe the castor arm bushes could be on there wayout and could be making a similar sound.
I plan on tracking it down this weekend as it drives me bonkers :evil:
eskimo
Postby 1I1 » Thu May 13, 2010 2:38 pm
eskimo wrote:Yea, first thing i check was the jack, spare wheel..under the spare wheel. Doesnt have a rear sway bar..yet 8)
No rear sway bar?!
TRD Clicky >>Here
1I1
Postby B_giB » Thu May 13, 2010 3:53 pm
No rear sway bar?!
That has rung alarm bells in my head too...
Current: SXE10 Altezza
Previous:AE86 Trueno Notch Back: Gone but not forgotten :cry: :(
AE101 Levin 20V super strut
1994 Mercedes Benz C280 Sport
B_giB
Postby Mr Revhead » Thu May 13, 2010 3:56 pm
Does for me now I his sig says GT AE111....
Postby 1I1 » Thu May 13, 2010 4:32 pm
Yup should have a 17mm rear sway bar unless for some very very odd reason it's been removed..... Or he had a typo when he wrote that!
TRD Clicky >>Here
1I1
Postby B_giB » Thu May 13, 2010 4:36 pm
And Caster bushes are in the front
B_giB
Postby Mr Revhead » Thu May 13, 2010 4:38 pm
You would not beleive the different names people have for some things!
Had an arguement with a guy after "control arm bushes" for the front of his implala.
Turns out he was after the castor rod bushes.... :x
Postby eskimo » Thu May 13, 2010 7:51 pm
Yea it has no rear sway bar.. and ive been looking for one to put in. Ill post a pic shortly
eskimo
Postby eskimo » Thu May 13, 2010 8:13 pm
Uploaded with ImageShack.us
Ok so here is the rear end of my car, what I thought were castor arms are the ones running from the middle to the hubs
eskimo
Postby Mr Revhead » Thu May 13, 2010 9:25 pm
Ah control arms, radius arms etc etc :lol:
Just be aware that some of those are spherical bearing bushs so they rotate easily
Postby eskimo » Thu May 13, 2010 9:53 pm
Sweet cheers for that, if they are worn could they make a similar sound?
eskimo
Postby allencr » Fri May 14, 2010 12:42 pm
eskimo wrote:Sweet cheers for that, if they are worn could they make a similar sound?
Sure.
Also, shake the exhaust and check/lever/twist/pull on all the suspension joints at the wheel's hub and all the suspension joints from the top of the body to the wheel's hub.
allencr
Postby eskimo » Fri May 14, 2010 1:07 pm
Sweet, will track down the source of the sound this weekend.
I have sourced a sway bar too :D (thanks Rick!) & I assume the AE111 trueno/levin one will bolt up without any issues.
eskimo
Postby 1I1 » Fri May 14, 2010 3:38 pm
Should be fine. I fitted a BZR to mine, floor pan and rear suspension etc in the sedan is the same as coupe
TRD Clicky >>Here
1I1
Postby eskimo » Fri May 14, 2010 11:43 pm
Cheers. mite need to get a few bits and bobs to mount it from you depending what bits come with the bar & what condition they are in
eskimo
