i have a Mr2 that overheated a few weeks ago, caused by a stuff thermostat which was replaced and solved the overheating issue.
Now the cooling system is bubbling and foaming none when i try to bleed the system... and uses about a cup of water every 1 or 2 days....
Done TK test OK
Done cooling system pressure check OK
many attempt to bleed the system. with the heater bleeder and radiator bleeder opened to bleed out the air.
car dont overheat anymore but i cant figure out why its bubbling
anyone got any ideas
