where to get 20V shims?
Postby matt dunn » Tue May 18, 2010 11:59 pm
I have some aftermarket cams that I have had for some time but not used.
I have test fitted them in an engine but the exh cam gives problems with shims. It must be reduced base circle? maybe,
as the shims that I need to set valve clearances are bigger than what Toyota can supply.
Does anyone know where you can buy larger shims for the 4AGE 20V engine?
Matt
Postby frost » Wed May 19, 2010 12:37 am
i think kelford cams have some,
Postby AceSniper » Wed May 19, 2010 5:48 pm
franklin cams do them also round 200+gst for set of 20
AceSniper
