How to get an engine to warm up faster?
Postby Burning Angel » Wed May 26, 2010 5:34 pm
My tt140 corona has a pushrod 2T.
it takes ages to warm up making the demister useless.
i can leave it idling for ages in the morning and it will only just reach the "C" on the gauge, it takes a good thrashing or extended driving to get the temp to come up but even then its not great.
when i first had it the temp wouldn't come up at all, which i thought was the thermostat sticking open. It turns out it had a 77° thermostat in it, so i replaced it with the standard 82° one.
I can go to a 88,89 or 91° thermostat which would raise the temp once its warmed up but I don't think it will get it to warm up quicker.
Anyone have any ideas?, or is this just an old car thing?
Also the poor heater performance could be a blocked heater core, but it would still be nice to have the engine warm up quicker for fuel economy etc.
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby sergei » Wed May 26, 2010 5:47 pm
Turning off the heater while it is warming up speeds it up.
It should take about 5min to fully warm up.
I don't think you have A/C but using that also helps faster warm up (plus it will clear the windscreen almost instantly).
Postby thegreatestben » Wed May 26, 2010 5:47 pm
Burnouts.
thegreatestben
Postby Burning Angel » Wed May 26, 2010 6:04 pm
sergei wrote:Turning off the heater while it is warming up speeds it up.
I havent tried this but i suspect i could leave it idling for 20min and it would still not warm up, and yes i do have the heater of when i let it warm up.
I had suspected also that the new thermostat had gone bad but it has been fine when checked several times.
I has no A/C, and i don't think Burnouts would go down too well a 6am lol, also at that time of morning it only takes ~5min to get to work which is just about all down hill and even then im still giving it shit to try and demist the windows lol
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby sergei » Wed May 26, 2010 6:40 pm
Sounds like thermostat issue.
Is it sealing properly? Perhaps the O-ring is missing?
Postby Mr Revhead » Wed May 26, 2010 6:45 pm
Does it have a viscous fan?
Postby Burning Angel » Wed May 26, 2010 6:53 pm
no o-ring on these, they're a non-bypass style thermostat too.
yes it has a viscous fan
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby metal_sean_head » Wed May 26, 2010 7:04 pm
thegreatestben wrote:Burnouts.
+10000
VTEC: All of the lag and none of the boost.
89 AE92 FXGT
Big Port Redtop
TVIS!
19.8@32kph
metal_sean_head
Postby Quint » Wed May 26, 2010 7:09 pm
Burning Angel wrote:yes it has a viscous fan
Check it hasn't seized.
Quint
Postby Burning Angel » Wed May 26, 2010 7:22 pm
nope not seized, although that wouldn't affect its warming up as the thermostat is closed.
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby ihavelift » Wed May 26, 2010 8:10 pm
if it makes any difference when i got the cambelt/thermostat/waterpump etcetc changed on my st205 it went from warming up in 10 mins to warming up in less than 2 haha
Current: 2000 Honda Accord Wagon CF6
Previous: 97 Toyota Celica GT4 ST205; 2001 Toyota Allex RS180, 96 Nissan Sentra SG
Low, Slow, Clean and Mean
ihavelift
Postby matt dunn » Wed May 26, 2010 8:34 pm
Does the thermostat have the wee hole and valve in it for bleeding?
If so one without it may make a small difference.
Postby whynot » Wed May 26, 2010 11:21 pm
Put some heat trace on the block and wire it into a pull out plug with a time clock. set it for an hour before you leave for work and problem solved. Seen ambulances with similar down south but it was a element in the radiator and a electric pump to stop them freezing when parked up
whynot
Postby frost » Wed May 26, 2010 11:43 pm
start a small wood fire under the sump in the morning then go have breakfest so its nice a warm when you get going,
:D
i've seen guys in china take a gas flame burner to the sump in the winter time,
i too have a slow to worm up car, by the time i parkup at work the heater is a slight hot breeze,
Postby strx7 » Thu May 27, 2010 8:14 am
what is the real issue here, that you cannot demist your windows? is that what you are trying to achieve?
radiator
Postby ezy10s » Thu May 27, 2010 9:36 am
try covering most of your radiator with carboard blocking it from airflow maybe?
Member #244
ezy10s
Re: radiator
Postby iOnic » Thu May 27, 2010 9:46 am
ezy10s wrote:try covering most of your radiator with carboard blocking it from airflow maybe?
Radiator does very little during warm up.
true
Postby ezy10s » Thu May 27, 2010 9:48 am
but when all else fails....
Best way to get that thing to warm up would be to move to a warmer climate!!!
Member #244
ezy10s
Postby strx7 » Thu May 27, 2010 4:42 pm
if you are only worried about demisting your windows. give the windows a bloody good clean, mix up some detergent with a little water, smear it all over the inside of the windows, let it dry, buff it off, hey presto no fogging up........
Postby cat007 » Thu May 27, 2010 6:05 pm
strx7 wrote:if you are only worried about demisting your windows. give the windows a bloody good clean, mix up some detergent with a little water, smear it all over the inside of the windows, let it dry, buff it off, hey presto no fogging up........
Really? Like dishwashing detergent?
