Reinstalling 4WD Gearbox to 3SGTE
Postby loudstealthGT-Four » Mon May 31, 2010 1:47 am
Having a nightmare trying to get my 4WD gearbox reconnected to my 3SGTE, can someone please shed some light on a way to do this, I've just been trying by myself and would imagine it would be somewhat less of a mission with 2 people. But yea is there a nac to it or do i just have to keep fiddling around with the bloody thing :evil: till its goes on.
Any help and advice much appreciated
Tyler
loudstealthGT-Four
Postby Akane » Mon May 31, 2010 4:23 am
align up the clutch disc first before tighten the pressure plate?
Postby loudstealthGT-Four » Mon May 31, 2010 8:20 am
Yip done that :)
loudstealthGT-Four
Postby sergei » Mon May 31, 2010 9:20 am
Let me guess: the transfer case is hitting the block in some way.
You will need to turn the gearbox along the crank axis ~15' clockwise, slide it in so it is touching the locating pins, and turn it back up.
It is very fiddly.
I hope you are not doing it in the car?
Last time I was doing it myself, and I had to put engine crack pulley down, so the engine was sitting vertical (make sure you have some wood blocks in strategic places) and place the box on top and fiddle with it for a while until it "fell" in place.
Postby Boosted_162 » Mon May 31, 2010 10:57 am
sergei wrote:Let me guess: the transfer case is hitting the block in some way.
It is very fiddly.
Good advice, thats how i did mine. Spent hours with it on the ground, stood it up and had it on in 5 mins.
Postby sergei » Mon May 31, 2010 11:39 am
It is very fiddly.
Yeah, I forgot to add that obviously gearbox and engine must be dry, unless you want the oil everywhere.
Postby XS1V » Mon May 31, 2010 12:00 pm
Just got to hold it in the right position. I do them while hanging on the crane, tilt gearbox 15' anti clockwise and lower the back end another 15' then aim the input shaft at the clutch and lift and twist :wink:
Makes it sound so easy like that but yes it is a bitch the first few times, you will get there :)
Brad
ST205 Group A Rallye #2363
XS1V
Postby loudstealthGT-Four » Mon May 31, 2010 9:49 pm
yea definatly sounds easier in theory, not so much when i try it :). (keep on trying)
loudstealthGT-Four
Postby loudstealthGT-Four » Mon May 31, 2010 10:58 pm
ok got it on, well not completely still got to go on another 50mm. I stood the engine up on its end and lifted the GB on top of it using the engine crane. then because the crane was in the way i unhooked it from the GB and man handled it and then 8O ... it fell over 8O opps.... didnt damage anything... fingers crossed :oops:
given up for now, too cold. Will resume later and try and get it on completely and bolted up and ill be :D
loudstealthGT-Four
Postby sergei » Tue Jun 01, 2010 9:08 am
loudstealthGT-Four wrote:ok got it on, well not completely still got to go on another 50mm. I stood the engine up on its end and lifted the GB on top of it using the engine crane. then because the crane was in the way i unhooked it from the GB and man handled it and then 8O ... it fell over 8O opps.... didnt damage anything... fingers crossed :oops:
make sure you don't force bolt it. As it might bend the clutch disk.
gt4 clutch
Postby tech128 » Thu Jun 03, 2010 10:46 pm
i used to grind a few places that touched just a little nt 2 much
and made it heaps easyer also had a spare input shaft that i used 4 alighnment
is it a multi clutch or single
tech128
Re: gt4 clutch
Postby loudstealthGT-Four » Fri Jun 04, 2010 2:00 am
tech128 wrote:i used to grind a few places that touched just a little nt 2 much
just a single plate.
YAY Got the b%@$&!!!!! on :D
Thanks a bunch guys, your all awesome!!
:D :D :D :D :D :D :D
not sure if you noticed but im quite pleased its back on
loudstealthGT-Four
Postby celica_xr9145 » Fri Jun 04, 2010 8:05 am
So when do you plan on having it running again?
celica_xr9145
Postby crispy'86 » Fri Jun 04, 2010 1:49 pm
HHmmm that's not a bad idea. might try that next time i do a rav box. We had one in the other week and i split the transfer from the box, removed power steer pump, slid tranfer back, removed box. I suspect the shaft that drives the transfer can be removed with a slide hammer if i did it this way next time. I just found it easier but then again we did have a hoist and stuff. Lots of good times there :lol:
crispy'86
Postby loudstealthGT-Four » Fri Jun 04, 2010 6:57 pm
celica_xr9145 wrote:So when do you plan on having it running again?
Hopefully within the next month :D , just got to sort out all the fuel and air lines and stuff
loudstealthGT-Four
Postby Lloyd » Sat Jun 05, 2010 9:02 am
sergei wrote:make sure you don't force bolt it. As it might bend the clutch disk.
You don't just get 2 bolts started and rattle them up???
Clearly there are ways you could be saving time Sergei :P
