Failed WOF for suspension too low?
Postby GT4-Addict » Mon May 31, 2010 6:16 pm
So i just took the GT4 in for a wof today. They reckon the front suspension is to low, i.e under 100mm clearance.
I have never failed a wof on this in the time i have had it so far, so i am wondering how VTNZ test for the clearance?
kinda pissed of really, they checked my car in such detail that they also noticed the bonnet is missing a spring in the catch!
GT4-Addict
Postby .:O4AGTZ:. » Mon May 31, 2010 6:21 pm
dont they just take it from the lowest point on the car and measure down? Just pump the tires up some more and take it back lol
.:O4AGTZ:.
Postby GT4-Addict » Mon May 31, 2010 6:26 pm
im assuming this means they take it from the sump? prehaps i will just pump up the tyres and see what happens haha
GT4-Addict
Postby iOnic » Mon May 31, 2010 6:33 pm
Lowest structural/chassis point. Sump, exhaust etc don't count. The VTNZ I go to has a wooden block that is 100mm high that they put under the lowest point to see if it clears.
Postby Lloyd » Mon May 31, 2010 6:34 pm
Anything that doesn't clear, except light stuff (ie bodykits) and the exhaust system will be a fail. Easiest way to check is throw a block of 4x2 under and see what it hits. And don't go to VTNZ :P Though if it was under 100mm and not certed I would have failed it too
Postby Paulio » Mon May 31, 2010 6:45 pm
"a minimum of 100 mm ground clearance exists below any part of the vehicle structure, or any steering, braking, or suspension component1"
1"does not include such items as exhaust pies and exterior body panels that do not contribute to the structural strength of the vehicle
usually from the sill, man.
check the 4x2, obviously, a laser frame 4x2 aint 100mm its 90mm.
yees booy
Paulio
Postby GT4-Addict » Mon May 31, 2010 6:54 pm
Ill go round with a ruler. there is no way that my sill is under 100mm from the ground. i might take some photos etc as proof when i go back in, and insist on watching when they do it. the car has passed 4 warrents the way it is while i have had it, and it is not any lower now than it has been in the past
GT4-Addict
Postby B1NZ » Mon May 31, 2010 7:19 pm
Unless you have a 100mm ruler you may find things difficult to measure under the car, Best idea as people have said is to cut a 100mm block of timber and drag it around under the car and check structual points/suspension and steering etc for clearance, If its close mayby some different size wheels or more air pressure may help as a temp fix?
If it clears then take it back and get them to recheck it, if they still fail it get another WOF place to check it and issue a WOF, then ask for your money back from VTNZ
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby GT4-Addict » Mon May 31, 2010 7:28 pm
Im thinking about putting my mates commodore wheels on it and taking it back. i will get a 100mm block of wood tomorrow and double check, just in case it is out but only by a small margin. if it is out then i have no problem with them failing it, it is just that i believe it is not too low at the moment.
Time will tell!
GT4-Addict
Postby GT4-Addict » Mon May 31, 2010 7:38 pm
Just confirming, the sump IS NOT part of what can be checked, am i correct?
GT4-Addict
Postby sergei » Mon May 31, 2010 7:55 pm
GT4-Addict wrote:Just confirming, the sump IS NOT part of what can be checked, am i correct?
Yeah, but in GT4 the lowest part in that area is the hump on the crossmember (which is lower than the sump).
Postby GT4-Addict » Mon May 31, 2010 7:57 pm
And that can be checked? well i guess it would be able to seeing as its the cross-member
GT4-Addict
Postby GT4-Addict » Mon May 31, 2010 10:38 pm
Hmm looks like i may have to eat my hat here. I just tested it. i have miles of clearance under all the sills etc, its just the darn crossmember, i need to gain about another .5mm at the front! it was more like 1-2mm but i cranked up the tyres to 45psi and i am so close haha!
Does anyone have some easy ideas to get that extra .5mm out of the suspension?
GT4-Addict
Postby Dell'Orto » Mon May 31, 2010 10:43 pm
Pull the carpet out
Postby 99gtt » Mon May 31, 2010 10:47 pm
just stick some 5 mm spacers under the 3 bolts on your camber plate / strut towers under the bonnet
SOON TO BE 500 HP
99gtt
Postby GT4-Addict » Mon May 31, 2010 10:58 pm
Yea, that idea literraly must have just occured to me while you were typing this. I think that might be the awnser im looking for, although any other ideas are still appreciated!
GT4-Addict
Postby loudstealthGT-Four » Mon May 31, 2010 11:05 pm
remove the engine and gearbox :D , that'll give you plenty of clearance :wink:
loudstealthGT-Four
Postby GT4-Addict » Mon May 31, 2010 11:23 pm
Might be a tad hard to explain why i had to push it into the VTNZ testing center haha. i could dump my 4afe i have here into it i suppose!
GT4-Addict
Postby metal_sean_head » Mon May 31, 2010 11:50 pm
They would have to be complete wang's to pick you up on .5mm.
Take it in like that and see
VTEC: All of the lag and none of the boost.
89 AE92 FXGT
Big Port Redtop
TVIS!
19.8@32kph
metal_sean_head
Postby celica_xr9145 » Tue Jun 01, 2010 12:01 am
i can't imagine how low this must be, when i had my GTR Celica, that used to scrape over most bumps and that was on factory springs. Can't imagine what this must be like, bet it looks good though.
celica_xr9145
