starlet gt not boosting or going like it should
Postby tech128 » Thu Jun 03, 2010 11:23 pm
hi just got a 4efte starlet it doesnt have any pull at all
it drives like it has no turbo
it has a bov it has a adjustable fuel pessure regulator on the return of the
rail.it has a scream pipe but doesnt make a noise at all bit weired
the engine revs fine doesnt miss or hesitate starts good an all
has a pod filter and factory top mount intercooler
heres the thinng it says acording to the boost guage which is connected to the same line as the bov 12psi boost which goes up to that
the bov is working etc but no feel at all just noise
what should i look for ist plugs and colour rich or lean
compresion has done 222k doesnt blow smoke blue
waste gate seizure is this common
not too sure about the fuel presure what is the standard value
and intercooler leaks maybe test the bov or waste gate actuators
and map sencor any other ideas would b much apreciated
might do a te1 an e1 aswell
cheers guys
tech128
Postby GT4-Addict » Fri Jun 04, 2010 12:19 am
What?
GT4-Addict
Postby Akane » Fri Jun 04, 2010 1:10 am
lolwat?
my Sis's Glanza V ages back, the turbo did seize at one stage tho, due to lack of oil change, wasn't by that much too.
But if you're getting a boost reading then it's something else.
Postby TRD_ZERO » Fri Jun 04, 2010 8:29 am
Try using a fullstop in your explination.
Previous:
TRD_ZERO
Postby maddog » Fri Jun 04, 2010 9:47 am
Try make your posts a bit more tidy :lol:
I'm no mechanical expert but I guess if you're getting a boost reading it's nothing turbo related; you'll probably have to look at your throttle... throttle cable loose, sticking throttle body, something like that perhaps?
Just a suggestion. Maybe one of the more experienced guys can suggest if this is a possibility.
-- 1992 AE101 Corolla FX-GT --
maddog
Postby sergei » Fri Jun 04, 2010 9:53 am
It is a poem!
So do you hear turbo spooling up?
Are you sure you have boost?
Remove intake pipe off turbo and have a feel around compressor, see if it turns freely.
Postby loose_unit » Fri Jun 04, 2010 11:19 am
Is it still running factory turbo? There should be no need for a fuel pressure reg if so, they run pretty rich as it is anyway. If the base pressure has been turned up then it may be running super rich which would explain why its really gutless. Id be taking the fuel reg off and returning that side of things back to stock and seeing if it gets any better.
91 GT Starlet 5efte
231kw atw @ 18 psi
12.13 @ 185kph
loose_unit
not boosting well
Postby tech128 » Wed Jun 16, 2010 6:37 pm
I removed the sparkplugs on the starlet in the weeknd.And i have found that the engine is running lean.
I set the aftermarket fpr between 35 and 40 psi it was on about 20 or so.
i also found a large spring that was in the engine bay and found that it belonged to the bov.
i hav checked the turbo for play and freeness turns fine.
also found the dump pipe loose and the outlet of the compressor pipe loose aswell grrr.
any other ideas woud be great.
tech128
Postby tsoob » Thu Jun 17, 2010 11:29 am
mate where in the country are you?
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
boost
Postby tech128 » Wed Jun 23, 2010 11:40 pm
in auckland out west.
got it running bit better ahy.
has a modded dump pipe which has a cat and sumone has put a scream pipe on and then welded it up for a wof.
so major restrictions there looks like bugger all flow
need a 2.5 de cat pipe.
whats the ignition timing and standard fuel pressure on these
hav mine on 40psi
tech128
