7AGE????? anyone done it here?
Postby BL8KK9T » Thu Jul 17, 2003 1:51 pm
has anyone here made a 7AGE with 7AFE block and 4AGE head?? what modification need to be made???? 16 valve we talking about,
yes officer, our sober driver is right behind us
BL8KK9T
Postby MrOizo » Fri Jul 18, 2003 1:44 am
i dont know anyone personally thats done it but i have a 7AFE sitting in the driveway at the moment ? :twisted:
too bad its the company car.
MrOizo
Toyspeed Legend
Postby mister2 » Fri Jul 18, 2003 2:42 pm
a mate of mine (i think dales on here) is doing it, using a 7afe and a s/c mr2 to make a 1.8l s/c. should be interesting. there was a 20v 7age turbo in australia, www.turbofast.com.au, and some ppl have done it on www.club4ag.com
nick
www.nzefi.com
4WD Dynapack Dynamometer.
Link, MoTeC, Greddy, Power FC sales support and tuning.
Weapon of Choice: 1992 NSR250 SE
On hiatus, current location: Cambridge, UK
mister2
Postby dodgy » Fri Jul 18, 2003 5:58 pm
ive thought about making a s/c 7age before, but have been told that the conrods are too weak so the cost of new ones put me off.
dodgy
Postby BL8KK9T » Sun Jul 20, 2003 11:19 pm
sounds like fun!!!! well cool thanx guys!! :P
BL8KK9T
Postby swamp » Sat Aug 14, 2004 5:25 pm
yeah ive just done it, just going thru the tuning stage at the mo with the link. good low down torque, pulls really well. definately worth it, be heaps better once run in and fully tuned
swamp
Postby Lloyd » Sat Aug 14, 2004 5:43 pm
Have a search on the net for it, its been done a fair few times. I was looking at it a few weeks ago ask I want to make a 7AGTE (7A block, crank etc, 4AGE head and a turbo). Found a few good reads. You'll need a longer cambelt, one off a porsche 944 (or 924) is a perfect fit apparently. But if you're actually set on doing this then you'll find these things out with a little searching :) Best of luck, and if you do do it then chuck up some info about how it went and issues you came across
Postby fangsport » Sat Aug 14, 2004 7:30 pm
if you ask Mr Sollitt (aka Trdman) very nicely, i believe he has help a couple of guys to do this conversion.
fangsport
Postby rollaholic » Sun Aug 15, 2004 12:27 pm
checkout www.corolla-racing.com, its an american site and all they really get are 7AFEs in their rollas, theirs a bit of info there about it.
Postby spencer » Sun Aug 15, 2004 12:33 pm
That link is dead bro
ms63 crown
spencer
Postby badidas » Sun Aug 15, 2004 3:21 pm
i saw omething on a site of someone who is very experienced in these sorts of adaptations and he said that the costs out weigh the bennifits
and the result is a higher powered weak engine
no offence to people who have/are doing it this is just what i read
ill try find the link for it
1989 mazda bongo aka [BNGBUS]
badidas
Postby Lloyd » Sun Aug 15, 2004 4:33 pm
Postby NZ_AE86 » Sun Aug 15, 2004 5:03 pm
This conversion has been done in many different ways but all you end up with is a weak engine. If you want more power turbo a GZE engine. If you want to go class racing then spend some money on a 16V 4A-GE.
Just my 2c. :D
NZ_AE86
Postby ants_ae92 » Sun Aug 15, 2004 9:26 pm
Idea is there for more power and torque but at more money. Yes conrods are weak. Also 7afe flywheel is not as strong, 6 bolts instead of 8, or something along those lines. So less strength in conrods = less max rpm. You can still rev it to the 4age limit with new rods. But in bang for buck wise, better to put the money into better mods for a 4age, like a gze, or turbo. Club 4ag has some good info(you no americans bigger is better) , and the aussie one looks mad. Lots of folding stuff though.
With limited cash stick to a 4age. If your going all out, the 7age might be for you, but only if its done with no expense spared.
ants_ae92
Postby Deno » Sun Aug 15, 2004 10:19 pm
As Nick said, I'm giving it a go. My aw11 SC bits all bolted onto a 7afe block. (pistons swapped of course). Yes the rods are weaker but are normally only a problem if you want to rev high. I have been talking to a guy in the states who did the same thing but with a twin charge set-up. Has had no problems with standard rods and is making good power. I just want to try it to be different. Unfortunatly I have not got time to spend on it at the mo (working 7 days) but should be back onto it at Xmas time.
You're just jealous the voices are talking to me!
85 MR2 NA faded red
86 MR2 Supercharged
90 Starlet GT (sold)
93 AE101 Levin parts car (PM if you need anything!)
97 Carib Sprinter (sold)
Deno
Postby SIDE_FX » Mon Aug 16, 2004 1:52 pm
u only need the 7afe crank nd pistons ive heard that i fits in a 4age block
SIDE_FX
Postby strap-on » Mon Aug 16, 2004 5:16 pm
it should do, i read the 7afe is just a stroked out 4a
strap-on
Postby spencer » Mon Aug 16, 2004 5:23 pm
got20v? wrote:it should do, i read the 7afe is just a stroked out 4a
no the block is different has a deck hieght of around 206mm as to the 4a's 190ishmm deck height. Too many people on the net say I heard this and that
ms63 crown
spencer
Postby Lloyd » Mon Aug 16, 2004 6:26 pm
Its a stretched and stroked 4A block :)
Bore on both 4A and 7A is 81mm, storke is 77mm and 85.5mm respectively.
http://www.geocities.com/MotorCity/Pit/ ... gines.html
Postby TRD Man » Tue Aug 17, 2004 11:43 am
TRD Man
