I have also tried hitting it with a hammer, haven't tried dropping it from a height yet
So just before I hit up the local PaP, is there anything else i should be looking at??
Thanks
20v_rollaboy wrote:Car is a 3s-ge Curren, suddenly wouldn't start. Put some jumpers on it and same response, just clicking. Checked all fuses and all is good. So I pulled the starter motor out and turned over. All that happens is the gear jumps up and down and it doesn't really turn over.
I have also tried hitting it with a hammer, haven't tried dropping it from a height yet![]()
Thanks
20v_rollaboy wrote:...pulled the starter motor out and turned over. All that happens is the gear jumps up and down and it doesn't really turn over.
20v_rollaboy wrote:I am an electrician![]()
I haven't pulled it apart yet, not enough light hours in the day
Mr Revhead wrote:Even I know choc blocks don't belong in dash's!!!
