Evo fuel pump swap in
Postby gleem » Tue Jun 08, 2010 9:30 pm
Putting an evo 8 fuel pump in my rb20det. Got one then looked up on line and saw this
http://www.roadraceengineering.com/evo/ ... mpinfo.htm
"The EVO 8 uses a dual voltage fuel pump. As we found out a long time ago, if you increase the voltage to the fuel pump with better and more direct wiring, it will flow more"
"When demand is low, they run the fuel pump voltage through a resistor. When fuel demand is higher, the ECU triggers a relay to run voltage straight to the pump instead of through the relay"
Im not sure about my cefiro but i doubt it has anything fancy like that.
So my question is will this be fine to use withought the resistors, relays etc or will it run lean? as the pump must be designed around the evo 8 wiring systems?
gleem
Postby Malcolm » Tue Jun 08, 2010 9:41 pm
yes it'll be fine. The same thing is done in many cars, e.g. ST185s, SW20 turbos
Postby Stott69 » Tue Jun 08, 2010 9:44 pm
Could wire in a variable resiostor, then you could control the fuel rate?
Image jzs147 Aristo money pit
Stott69
Postby matt dunn » Tue Jun 08, 2010 10:34 pm
The reason that two speed fuel pumps are used in factory,
is to reduce noise while idleing.
Postby frost » Wed Jun 09, 2010 1:18 am
matt dunn wrote:The reason that two speed fuel pumps are used in factory,
how about the "longer life of pump" is that true?
Postby matt dunn » Wed Jun 09, 2010 1:20 am
i wouldn't have really thought that was the case,
But interestingly enough it is mentioned that it reduces emissions in the fuel tank,
by causing less fuel vapours as there is less fuel returning to the tank.
Postby Akane » Wed Jun 09, 2010 5:52 am
Rumour has it that it increases pump life.
Just run it straight, if the pump is half decent it shall outlast a cefiro anyway :)
Postby gleem » Wed Jun 09, 2010 9:03 am
ok thanks. just confirming my thoughts. so if run straigt it will be running at full the whole time? which is what i want
gleem
Postby gepsk8 » Wed Jun 09, 2010 9:49 am
i believe variable voltage pump wear out fast not slower, normal on all Nissan & Subaru's fuel pump needs to be replaced before 200k's
as Toyota & Honda one do over 250k's easy normally
O272754663
gepsk8
Postby tsoob » Wed Jun 09, 2010 12:38 pm
Akane wrote:Rumour has it that it increases pump life.
:lol: :lol: :lol:
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby gleem » Sun Jun 13, 2010 3:10 pm
turns out evo fuel pumps are 160lph and 20dets are 190lph even though late model evos are what, 300hp standard
gleem
Postby matt dunn » Sun Jun 13, 2010 8:41 pm
gleem wrote:turns out evo fuel pumps are 160lph and 20dets are 190lph even though late model evos are what, 300hp standard
Was thinking that, most people I know say you need to upgrade a std EVO pump even to run 18psi on a std engine as the pumps are on the limit,
although you'd expect the later ones to be better.
