C5* vs E5* gearbox weight?
Postby gmacrae » Fri Jun 11, 2010 8:22 am
I'm thinking about putting a LSD e5* gearbox from an ae92 gtz in my ae92 (20v). I like the taller gearing in the 4agze gearboxes. Does anyone know the actual difference in weight of the 2 types of gearbox?
Gene
gmacrae
Postby thegreatestben » Fri Jun 11, 2010 8:32 am
think it's about 30kg vs 60kg
thegreatestben
Postby KinLoud » Fri Jun 11, 2010 9:13 am
Yeah - my grunto meter (from muscling gearboxes into place) would say that C gearboxes are about 35kg and E boxes about 50 to 55kg.
Ken
Postby Bazda » Fri Jun 11, 2010 9:19 am
I duno why you would put a E series into a 20v. Thats taking a step backwards. Unless its a turbo 20v.
Postby gmacrae » Fri Jun 11, 2010 9:33 am
yea i didnt realise the weight difference was that much. I just like that they rev lower at 100ks, and the lsd would be nice
What is the top/final gearing like in the 6speeds? Any taller?
gmacrae
Postby sergei » Fri Jun 11, 2010 9:58 am
gmacrae wrote:yea i didnt realise the weight difference was that much. I just like that they rev lower at 100ks, and the lsd would be nice
For top gear 6speed is very close to top gear for 5speed.
Postby Bazda » Fri Jun 11, 2010 10:07 am
Its not the weight that would be the backwards step, it will be the ratios of the E series box. They are no where near as close as a C series box.
ie 3rd gear on the E series box is really far from 2nd gear. 2nd takes you to around 90kph @7500rpm, 3rd takes you to 150kph @7500rpm.
You will also need a new clutch plate to suit the E series spline as thats 1-1/8" vs 15/16".
Postby 1I1 » Fri Jun 11, 2010 1:56 pm
Yup at 100k iirc 6th gear gets you about 3,000rpm (maybe 3,200)
TRD Clicky >>Here
1I1
Postby gmacrae » Fri Jun 11, 2010 2:06 pm
^hehe so which is it guys? 6th is close to the c56 (3500@100kph) or quite a bit taller (3000@100kph) ?
6spd ae92 would be pretty cool
gmacrae
Postby gmacrae » Fri Jun 11, 2010 2:27 pm
Found a gear/speed calculator i forgot i had, it says:
c160 6th @ 60mph is 2920
c56 5th @ 60mph is 3125
(with 195/50/15 tyres - gear ratios from wiki)
Guess my tacho must read high
Anyone got a ae111 c160 they wanna sell me? :)
gmacrae
Postby sergei » Fri Jun 11, 2010 2:27 pm
gmacrae wrote:^hehe so which is it guys? 6th is close to the c56 (3500@100kph) or quite a bit taller (3000@100kph) ?
About 3200 at 100kph. 6spd vs ~3400 at 100kph 5spd. Not huge difference.
Postby Quirky » Fri Jun 11, 2010 2:51 pm
E58 gearbox is 2900rpm at 100kph
The only real difference is third gear, I dont remember but its close to 155/160 when your stringing out the revs.
Never maxxed 4th or 5th.
Hello There
Quirky
Postby ATAl » Fri Jun 11, 2010 4:04 pm
The e58 (i think) that came with my ae92 gtz would sit about 3400rpm at 100, but it was a bit of an unknown what exactly that gearbox was.
ATAl
Postby DexGT » Fri Jun 11, 2010 9:07 pm
If you want to rev less at 100km/hr , fit the 3.7 diff from a starlet in place of the 4.3 that corollas have .
DexGT
Postby 85AW20v » Fri Jun 11, 2010 9:42 pm
I had an E5* in my AW when I first fitted the 20v and was doing the exact same lap times round the old Taupo track as with the 16v. Swapped back to the C52 and picked up 3 seconds a lap - the g/b was the only change I made. The E5* is basically the same box as the the 3SGTE runs and a 20v isn't quite up to that sort of output - close but no cigar. :D
And whenever someone starts poking out hundreds of hp in their SW, they never touch the g/b so it would be slightly overkill for a 20v....
See ya
Simon
85 MR2 20v
85AW20v
Postby Quirky » Sat Jun 12, 2010 12:34 am
ATAl wrote:The e58 (i think) that came with my ae92 gtz would sit about 3400rpm at 100, but it was a bit of an unknown what exactly that gearbox was.
You running 10inch wheels?
In 5th at 100kph it should be just under 3000rpm.
Am I wrong here?
What other gearboxs came with the ae92 gtz?
Hello There
Quirky
Postby ATAl » Sat Jun 12, 2010 9:29 am
15's with very close to the same rolling diameter as stock.
It's possible someone rebuilt the gearbox at some stage and changed the diff or something.
ATAl
Postby Bazda » Sat Jun 12, 2010 12:37 pm
yes with the E58 in 5th with 205/50/15s you should be at 102kph @3000rpm.
5th gear has a ratio of 0.82 and a final drive of 3.94
at 8000rpm in 5th you would eb doing 270kph :)
I changed my diff ratio from 3.94 to 4.29, so in 5th @100kph im at 3300rpm.
Postby DexGT » Sun Jun 13, 2010 12:08 am
You have a C52 box now with a 4.3 diff in it , if you want to do somewhere around 2700(been a while since I drove the car) at 100km then get the diff out of a starlet C52 box which is 3.7 .
I am currently going the other way to make my race car accelerate faster as I don't commute in it. :lol:
DexGT
Postby AceSniper » Mon Jun 14, 2010 6:56 pm
you don't even need a starlet diff... go grab a cheapo c series box off at 4afe/7afe and you wont have to rip it apart...
But I dont see your point in doing this.....
AceSniper
