AE111 Heavy steering
Postby celica_xr9145 » Sat Jun 12, 2010 7:04 pm
Not a problem as such but when i had my AE101 Trueno, the steering was really light, you could turn it with one finger. With my new AE111 Levin, the steering is fairly heavy. Honestly feels like im turning the steering wheel in a BMW.
Are they all like this? I would have thought it would have been the same steering system as the AE101.
If it makes a difference, it has 17's, lowered and a momo steering wheel (going soon).
Thanks
celica_xr9145
Postby sergei » Sat Jun 12, 2010 7:29 pm
If it is superstrut, then it is normal.
Postby celica_xr9145 » Sat Jun 12, 2010 7:35 pm
actually not sure, how do you tell without jacking the car up?
I thought all superstrut Levins had the 6 speed gearbox, mine is only a 5 speed and there is no sticker on the side.
celica_xr9145
Postby touge_ae101 » Sat Jun 12, 2010 8:56 pm
i don't think it is anything to be worried about. its the difference in the powersteering pumps between the 4afe and blacktop. i have noticed the same thing going from 4afe to 4age blacktop.
not that its a bad thing IMO, the light steering was always one thing that annoyed me.
touge_ae101
Postby sergei » Sat Jun 12, 2010 9:07 pm
celica_xr9145 wrote:actually not sure, how do you tell without jacking the car up?
Superstrut will have twin pot callipers, funky fig-8 joints that are visible under the car. The top ball joint on the strut is also give away (at same level as top of the brake rotor).
Postby celica_xr9145 » Sat Jun 12, 2010 9:43 pm
touge_ae101 wrote:i don't think it is anything to be worried about. its the difference in the powersteering pumps between the 4afe and blacktop. i have noticed the same thing going from 4afe to 4age blacktop.
Not worried about it as such, when i first drove it i didn't like the heavy steering but does feel quite nice once used to it.
Will get the front wheel off tomorrow and have a look if its SS.
Thanks
celica_xr9145
Postby sergei » Sat Jun 12, 2010 10:54 pm
You are looking for this:
If it has two bolts holding shock to the hub, then it is not superstrut.
Postby celica_xr9145 » Sun Jun 13, 2010 10:57 pm
Thanks for the pic, looks like my Levin has superstrut. As far as i'm aware i should have a factory LSD then :D :D
Thanks again
celica_xr9145
Postby touge_ae101 » Sun Jun 13, 2010 11:18 pm
celica_xr9145 wrote:Thanks for the pic, looks like my Levin has superstrut. As far as i'm aware i should have a factory LSD then :D :D
Thanks again
road test will tell you :lol: :lol:
touge_ae101
Postby nzhogrider » Tue Jun 15, 2010 10:14 pm
FYI I bought my Levin (96 superstrut 5 speed AE111 Blacktop) prior to having been vinned. During the vin inspection the guy failed it on only two things, front right wheel bearing stuffed = $$$ to buy replacement compared to normal Levin wheel bearings, and heavy steering. Point to note, I changed the wheel bearing and then took it back for a re-check and it passed. The steering had sorted itself out, but definately known to feel heavy occasionally compared to other set-ups. I prefer to have a little more resistance and pseudo-feel to the steering than the usual full power assist falseness, it makes it easier to get feedback from the road IMO.
nzhogrider
Postby celica_xr9145 » Tue Jun 15, 2010 11:39 pm
But if it was a wheel bearing, wouldn't there be other things i would notice?
Also, i had to guy at toyota confirm if i had superstrut and no i don't so not sure why my steering is heavy.
After turning a corner this morning, when turning full lock right, one of the front tyres judder almost like something is catching. CV's are all good, no wheel rub either. I read that the powersteering pump could be jumping a tooth on the belt, does that sound right?
Should probably note that the car has a split boot over the tie rod end bushing, performance tires up front, king springs, 16" lightweight wheels and a sportline steering wheel + boss. Don't know if any of that would make a difference.
celica_xr9145
Postby Bling » Wed Jun 16, 2010 12:52 am
Smaller steering wheel than your old car, wider grippier tyres, weak arm muscles. Could be anything.
Get it looked at by toyota, saves a lot of time if its not something you can work out yourself.
Postby touge_ae101 » Wed Jun 16, 2010 8:39 am
celica_xr9145 wrote:Also, i had to guy at toyota confirm if i had superstrut and no i don't so not sure why my steering is heavy.
its a blacktop thing not a superstrut thing. mine is the same.
powersteering belt is ribbed, doesn't have teeth. so would just slip. if you are feeling it judder, that is normally when the steering rack is running out of oil from the pump. we've had heaps of farm utes like that. might pay to get the PS pump checked new one is pretty cheap. toyota might be your best bet.
touge_ae101
Postby celica_xr9145 » Wed Jun 16, 2010 11:35 am
Solved, i have no powersteering belt :lol: :lol:
celica_xr9145
Postby Alex B » Wed Jun 16, 2010 11:43 am
celica_xr9145 wrote:After turning a corner this morning, when turning full lock right, one of the front tyres judder almost like something is catching. CV's are all good, no wheel rub either. I read that the powersteering pump could be jumping a tooth on the belt, does that sound right?
Welcome to the world of FWD LSD
Postby Mr Revhead » Wed Jun 16, 2010 12:29 pm
Only clutch pack type though, which are aftermarket...
Postby 1I1 » Wed Jun 16, 2010 12:39 pm
celica_xr9145 wrote:Solved, i have no powersteering belt :lol: :lol:
One of those might help!
These will still be a little heavy with wider tyres than stock. Even mac strut
TRD Clicky >>Here
1I1
Postby touge_ae101 » Wed Jun 16, 2010 1:38 pm
haha thats quite important to powersteering working! :lol:
let me guess...removed AC and was too lazy to find the correct belt to fit on with no tensioner?
touge_ae101
Postby celica_xr9145 » Wed Jun 16, 2010 2:01 pm
Haven't tried the AC yet :lol: the previous owner probably thought he was unrestricting power :lol:
celica_xr9145
Postby 1I1 » Wed Jun 16, 2010 4:22 pm
AC is too handy to just remove on a street car!!!
TRD Clicky >>Here
1I1
