celica_xr9145 wrote:im currently driving on 3 wheel nuts
seconded. they are as cheap as chips to buy. TWL or any good engineering shop should be cheaper than repco or bnt, as you should be able to buy them without the frilly packaging.sergei wrote:
If I were you I would replace whole lot. They are about $5 each. If one snapped there should be a reason why. Over-tightening is most common cause. At least you need to inspect all other ones for cracks and stretching in same place where the first one snapped.
And don't drive it with 3 wheel nuts.
h8wrxs wrote:you might be best off to take one of the others out and take it to repco with you, i had this problem a few months ago and they had all the studs in a box mixed up, not labelled or anything.... and they arent always a 5 min job, i had ALOT of trouble getting the old studs out...
h8wrxs wrote: and they arent always a 5 min job, i had ALOT of trouble getting the old studs out...
Dell'Orto wrote:No, PS pump isnt run off a cogged belt. Either your pump is knackered, or your tyres are underinflated.
celica_xr9145 wrote:Repco didnt have the studs so ended up going to Toyota. Have the day off work tomorrow to fix the car.
Is it really necessary to take off the hub? I've seen a lot of tutorials on removing studs with the hub left on with big american cars with loads of clearance but haven't had time to check how much clearance i have.
Malcolm wrote:sounds like you need to invest in a bigger hammer.
