Clutch Replacement
Clutch Replacement
Postby watchthisspace » Thu Jun 17, 2010 7:41 pm
Hey,
just wondering how much, roughly it would cost to get a clutch replaced in a 96' BZG??
Thanks in advanced!
Tim
watchthisspace
Postby MR2BOY23 » Thu Jun 17, 2010 7:59 pm
3-4 hours labour? + machining the flywheel
around $60 p/h so looking at $240+ depending on where you take it
Unless someone on here is willing to do a cash job for you. If your mechanically minded and get together with some friends it's a job you can do at home yourself.
MR2BOY23
Postby MR2BOY23 » Thu Jun 17, 2010 8:11 pm
Looking at around $3-400 for a tgp clutch kit too
About $60 for flywheel skim
MR2BOY23
Postby Alex B » Thu Jun 17, 2010 8:57 pm
MR2BOY23 wrote:Looking at around $3-400 for a tgp clutch kit too
Mine for the MR2 was around 200, i would hope a 4age one wasnt much more than that.
Postby watchthisspace » Thu Jun 17, 2010 9:55 pm
Thanks for the replies! Not looking as expensive that I first thought. But I'll still quote around a few places as I'm no good with cars.
EDIT: Are there any trustworthy places I can inquire about this?
watchthisspace
Postby levinguy » Thu Jun 17, 2010 10:19 pm
i think the tgp clutch kit is 199 plus (trade), so try and find someone who can get that price.
3-400 for it, even genuine, is just crazy for a 4age.
try mark the toyota forum sponser :)
then you'd just be looking at labour plus flywheel skim, its a fairly simple clutch to change.
levinguy
Postby watchthisspace » Thu Jun 17, 2010 10:45 pm
levinguy wrote:i think the tgp clutch kit is 199 plus (trade), so try and find someone who can get that price.
Cheers! I'll ring a few mechanics tomorrow and quote them about it.
watchthisspace
Postby Bling » Fri Jun 18, 2010 1:42 am
Add your location to your profile on here.
I'm assuming you are in chch, give Graham a ring, he's a good sort, would trust him with my car any day.
http://yellow.co.nz/companies/Automotiv ... 7_880.html
Postby allencr » Fri Jun 18, 2010 2:31 am
Many would also replace the MC & slave to complete the job. Their time is probably up too.
Also, engine & trans seals hardly cost anything when they're done along with the clutch.
Clutch master cylinder and slave cylinder, the thing the pedal pushes on that pushes the other thing that pushes the clutch.
They may also call it the clutches' hydraulics.
allencr
Postby watchthisspace » Fri Jun 18, 2010 11:58 am
BZG|Bling wrote:Add your location to your profile on here.
Sorry, have added location.
Thanks, Graham seems like a very friendly guy and quoted me one of the cheapest prices of getting the clutch replaced with a standard one.
@Allencr, may I ask what the MC and slave is?
Car noob but willing to learn.
watchthisspace
Postby rollaholic » Fri Jun 18, 2010 5:51 pm
the master cylinder is the hydraulic bit that the clutch lever actuates when you push it in, this transfers pressure to the slave cylinder which is bolted to the gearbox on your car, and pushes the clutch rod into the clutch fork, which dis-engages the clutch. both have seals which wear, which is why allencr was talking about replacing them.
Postby ihavelift » Fri Jun 18, 2010 7:24 pm
how much approx would it be for labour to change the clutch on an st205 gt4 celica? :roll:
and sorry for hijacking the thread by the way ... just didn't see the point in starting a new thread :P
Current: 2000 Honda Accord Wagon CF6
Previous: 97 Toyota Celica GT4 ST205; 2001 Toyota Allex RS180, 96 Nissan Sentra SG
Low, Slow, Clean and Mean
ihavelift
Postby Bling » Fri Jun 18, 2010 9:39 pm
watchthisspace wrote:Thanks, Graham seems like a very friendly guy and quoted me one of the cheapest prices of getting the clutch replaced with a standard one.
Just keep in mind cheapest quote isn't always the best way to go, worth paying a bit more to get it done by someone known to do a good job :) Make sure all quotes include the same things too, some might not include getting the flywheel skimmed etc.
Postby watchthisspace » Fri Jun 18, 2010 10:05 pm
rollaholic wrote:the master cylinder is the hydraulic bit that the clutch lever actuates when you push it in, this transfers pressure to the slave cylinder which is bolted to the gearbox on your car, and pushes the clutch rod into the clutch fork, which dis-engages the clutch. both have seals which wear, which is why allencr was talking about replacing them.
Thanks! Will add that to the list.
@BZG|Bling, good point, will have to ask again if I do get that BZG and it needs it's clutch replaced.
watchthisspace
