lightweight exhausts
Postby fxgt race » Thu Jun 17, 2010 10:54 pm
The car is on its winter diet, For mild steel how thin walled can one go for an exhaust, What other light weight materials can be used and is there lighter mufflers out there that you know off that can be used.
Pukekohe 1.07.6
Taupo 1.41.3
Manfield 1.18.7
hamptondowns 1.15.2
fxgt race
Postby d1 mule » Thu Jun 17, 2010 11:12 pm
titanium can be used but $$$$$
how much weigh do you think your going to save on an exhaust???
couple of KG tops i recon
d1 mule
Postby soopachargen » Thu Jun 17, 2010 11:25 pm
does the exhaust have to exit out the back? or can you dump it earlier??
When in doubt, down and out.
soopachargen
Postby Bazda » Thu Jun 17, 2010 11:37 pm
People have been using aluminium in the states. Not sure how long one would last..
Thin wall stainless is usually pretty light and lasts along time.
exhaust
Postby fxgt race » Thu Jun 17, 2010 11:48 pm
My exhaust is side exit just before the back wheel, Stainless is probably the best to use i guess. Anybody in auckland do stainless exhaust systems on TS
Pukekohe 1.07.6
Taupo 1.41.3
Manfield 1.18.7
hamptondowns 1.15.2
fxgt race
Postby Bazda » Thu Jun 17, 2010 11:54 pm
Evil Si on here can. aka Simon. He is a fabricator.
Im sure there are heaps of guys who can.
Postby Akane » Fri Jun 18, 2010 12:06 am
edit: nevermind.
Postby Bling » Fri Jun 18, 2010 12:12 am
Just have a lettuce sammy every day instead of a pie :lol:
lettuce
Postby fxgt race » Fri Jun 18, 2010 10:53 am
Im already in the bantam weight for boxing, weighting in at a measly 60kgs. I need me pies. Its weight at the moment and more power next year. As we say in losing weight , many crumbs make the big time cookie.
Pukekohe 1.07.6
Taupo 1.41.3
Manfield 1.18.7
hamptondowns 1.15.2
fxgt race
Postby Bazda » Sat Jun 19, 2010 12:19 am
Have you drilled holes throughout the car?
If you look back at the old shell sport cars they attacked everything with a hole saw!
Postby KinLoud » Sat Jun 19, 2010 8:46 am
Ha - I have read about drag racers in the states acid dipping the body (I presume the cars had full chassis) to make all the metal thinner.
Ken
acid dip
Postby fxgt race » Sat Jun 19, 2010 3:20 pm
Yep this car is down to single skin everywhere. Spot weld drill bit has been to town , every bracket ,piece of metal has been cut off. Ive i weighed the car now it would come in at 750kgs. Its nearly to a point where to concentrate on handling and more power, Have and adjustable in cabin blade swaybar going in this winter. If i was to acid dip this puppy i Think I would have a chassis and roll cage left
Pukekohe 1.07.6
Taupo 1.41.3
Manfield 1.18.7
hamptondowns 1.15.2
fxgt race
Postby Flannelman » Wed Jun 23, 2010 10:14 pm
I was told by a exhaust shop bender that the minimum the he can bend in a bender is 1.6mm.
Flannelman
formerly known as Affroman
Postby frost » Wed Jun 23, 2010 10:38 pm
sounds about right. but 1.6 is still quite thick,
most light weight (racing) Japanese exhaust systems are welded bends rather then machine bends,
the rs hamada exhaust system on my ae85 is super thin wall stainless and its welded, same with a friends titanium exhaust all welds,
they also dont have flange's but slip over type joins, saves quite alot of weight,
i had a honda exhaust header that had ribs machined into the head flange to save weight, also looked super tech,
Postby gasman » Wed Jun 23, 2010 10:39 pm
well if you had a honda buddy club make 0.8mm wall thickness exhaust systems. standard thickness that most mild steel in nz is 1.6mm, but for the stainless you can get it down to 1.2mm for 2.5" and 3" which is what i used on my corolla.
"What can possibly go wrong?"
gasman
Postby Flannelman » Thu Jun 24, 2010 5:41 pm
An after thought, too thin an exhaust will sound tinny.
Flannelman
Postby metal_sean_head » Thu Jun 24, 2010 5:51 pm
Affroman wrote:An after thought, too thin an exhaust will sound tinny.
Yeah it prob would.
But its a race car so he prob isn't bothered.
There is the buddyclub spec 2.
0.8mm thick
A racing spec muffler is a light weight and highly efficient muffler that is made to perform for circuit run. In its street version, to optimize torque in the low to mid speed range, it is equipped with an efficient middle silencer (resonator). Racing Spec Muffler were designed for high performance as well as meeting sound level standards. With its deep throaty tone, it echo's it racing linage.
Spec II is a specially designed system for competition use only. Its simple straight thru design creates an increase of exhaust gas velocity in order to improve efficiency. The middle silencer (resonator) on the main pipe is designed to maintain torque in the low to mid speed range.
Not sure if there will be one for your application. Unless you modify it or something?
VTEC: All of the lag and none of the boost.
89 AE92 FXGT
Big Port Redtop
TVIS!
19.8@32kph
metal_sean_head
