Strange water Leak (Urgent help toyspade)
Postby dnalunchie » Tue Jun 22, 2010 12:46 pm
Ok guys ive got a 1987 1.3 carbed swift
A couple months back it started getting hot and leaking water alot so we replaced the Head gasket and it all went sweet
Then about 2 months later it started getting hot again and using alot of water
So I took these photos of the water leak and it seems to be leaking from around one corner of what Im guessing is the sump?
Its dry elsewhere in the engine.
Before i got a chance to replace the BHG last time the engine did get pretty hot a few times so maybe the block has gone soft and wont seal properly?
There are no bubbles coming from the radiator cap when the engine is running and no milky residue around the oil filler cap either
Also the leak only happens when the car is running or when its been warmed up and will leak for a few moments with the car off (I think)
What are my options guys?
Strx7 has already hooked me up with a GREAT price for a new engine but i dont want to go down that road if its not nessecary?
Current: 90 3sfe Corona
dnalunchie
Just rang a mechanic friend of my, suggested it could be a leaking water pump as these are down by the cambelt on the drivers side which is exactly where the leak appears to be coming from, any thoughts here guys?
dnalunchie
Postby MR2BOY23 » Tue Jun 22, 2010 1:00 pm
fukd water pump, when the seals let go the water exits through a release hole which usually winds up dripping off the bottom of the block/sump under the timing case
MR2BOY23
Postby dnalunchie » Tue Jun 22, 2010 1:00 pm
Oh, if this is the case I will be VERY happy as thats a cheap/easy fix
Anyway I can check if thats the issue for certain?
dnalunchie
Postby Malcolm » Tue Jun 22, 2010 1:27 pm
if you can see the water pump pulley, there should be 2 holes on the water pump housing quite near the pulley, chances are that the lower one will have water coming out of it. Based on the symptoms it's almost certainly this, as the increase in pressure from warming the engine up forces the water past the seal.
Postby Malcolm » Tue Jun 22, 2010 1:29 pm
in this picture you can see the seepage hole on the snout that extends from the pump housing out to the pulley (this is just a generic water pump pic, but gives you an idea what to look for)
Postby GDII » Tue Jun 22, 2010 2:26 pm
Why haven't you got Laas onto this? Or has he refused to help you with your cars anymore? :lol:
1990 SW20 MR2
Previous 1990 EE90 Corolla
GDII
Postby dnalunchie » Tue Jun 22, 2010 2:28 pm
is there any risk in me trying to take it apart myself?
what do I need to do?
dnalunchie
GDII wrote:Why haven't you got Laas onto this? Or has he refused to help you with your cars anymore? :lol:
he is at work, being gay and workie
dnalunchie
Re: Strange water Leak (Urgent help toyspade)
Postby allencr » Tue Jun 22, 2010 2:35 pm
dnalunchie wrote:Before i got a chance to replace the BHG last time the engine did get pretty hot a few times so maybe the block has gone soft and wont seal properly?
NO, no such thing, but it does give the head bolts a bit of a stretch and some designs/sizes will be little loose & need to be re-torqued ASAP.
allencr
Postby dnalunchie » Tue Jun 22, 2010 3:02 pm
Is this just sumthing I can go at with a box of tools?
I believe I have to take the belt off but Is there anything I have to be wary of? Should I disconnect the batter for instance?
dnalunchie
Postby Malcolm » Tue Jun 22, 2010 3:15 pm
yeah it's usually pretty simple. Disconnecting the battery is usually a sensible precaution.
How much mechanical work have you done before? Provided you have a small amount of mechanical capability it should be doable in a couple of hours unless there's lots of crap in the way. Count the number of bolt holes on the new pump and make sure you've removed that many from the old one before you try to pop it off (there's usually a bit of force required because the gasket can stick them together pretty well). There is sometimes a countersunk bolt holding them together, which can be hard to spot, and it is usually a Philips head too which can be a real pain.
Postby rollaholic » Tue Jun 22, 2010 5:36 pm
someones been working on 3S's!
Postby whynot » Tue Jun 22, 2010 6:21 pm
If I remember right you will need to mess round with the cam belt tensioner to replace the water pump on these motors. If you have the tools and know how to change a cam belt then this will seem pretty straight foward.
whynot
Postby strx7 » Tue Jun 22, 2010 8:45 pm
whynot wrote:If I remember right you will need to mess round with the cam belt tensioner to replace the water pump on these motors. If you have the tools and know how to change a cam belt then this will seem pretty straight foward.
correct, cam belt tension attaches to water pump
i'd reccomend doing the water pump, and putting a sealwell cube into the cooling system, it should be good for another 20,000km +
Postby fangsport » Tue Jun 22, 2010 9:30 pm
strx7 wrote:
i'd reccomend talking nicely to me, and putting a G13B into the cooling system, it should be good for another 120km/h + grin factor
edited for truth, and logic
fangsport
Postby allencr » Wed Jun 23, 2010 4:20 am
dnalunchie wrote:Is this just sumthing I can go at with a box of tools?
No, if you have to ask, you can't, and considering the other questions asked, I'm pretty sure you can't.
Can you afford to learn the hard way, if not then don't?
allencr
Postby dnalunchie » Wed Jun 23, 2010 10:40 am
Woah! Negative bear says teach a man to fish!
dnalunchie
Postby MAGN1T » Wed Jun 23, 2010 10:58 am
Murphy's law says that the last headgasket job done on the car wasn't done properly.
Needs doing again.
Too much pressure blows the coolant our through the seal.
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby Malcolm » Wed Jun 23, 2010 11:17 am
MAGN1T wrote:Murphy's law says that the last headgasket job done on the car wasn't done properly.
Needs doing again.
Steve
Murphy's law? Sounds more like MAGN1T's law to me.
MAGN1T's Law wrote:BHG
