How to: Coil packs on a 20 valve
Postby ATAl » Sat Jun 26, 2010 11:56 am
I've got coil packs running on my 4age and thought anyone doing the same thing in the future may appreciate this.
What you need:
1zzfe coil packs, others apparently work but I haven't tried them
The wiring harness plugs with a bit of wire sticking out for the coil packs
After market ecu (link g4 in this case)
20 valve 4age of some sort.
How to install:
First you need to make the coil packs a tiny bit thinner, in the photo below the coil pack on the left has been filed and sanded the one on the right hasn't yet. You only need to take off about 1mm at the most, mainly to get rid of the ridges you can see.
All installed, I haven't bothered to bolt them down as the fit is very tight and they shouldn't fall out, will find out if this was a good idea after I've driven for a while :D
Next wire them up, in this pic red and black is +12v, green and red is trigger, white and black is ground and white and red is the firing confirmed signal, you don't need that one.
The +12v I wired to the main relay output, the trigger to the link ecu and ground to ground.
All wired up:
That's it, nice and easy really and they work well too.
ATAl
Postby Dell'Orto » Sat Jun 26, 2010 1:03 pm
Have you done a dyno run to see what difference they make? Would be interesting to see.
Postby ATAl » Sat Jun 26, 2010 1:17 pm
No, have just built this engine from scratch so there's no 'before' dyno. I doubt this would make a power difference, I've done it more to make sure there's a good spark at high boost levels.
ATAl
Postby Kittah » Sat Jun 26, 2010 2:39 pm
Not that I'm interested in doing this, but that's an easy and nice writeup :)
More to my point, out of curiosity as it is, what is the advantage of running coil packs?
Kittah
Postby Rick » Sat Jun 26, 2010 2:42 pm
You can also run them off the factory ecu, good for RWD conversions.
Postby Crampy » Sat Jun 26, 2010 4:17 pm
Been done with Honda K20A coil packs on stock Blacktops, stock ecu too. As mentioned, good for RWD, as you don't need the dizzy cap (no need to modify firewall)
Crampy
Postby XSVWGN » Sat Jun 26, 2010 5:39 pm
im using evo2 coil packs on mt 4agte. great conversion and much better spark. Alex your car is coming along fast ... cant wait to see this going. Oh and i cant wait to put mine up against yours haha ;)
Matt
021 297 1754
2008 Kia rio - work car
XSVWGN
Postby Quirky » Sat Jun 26, 2010 5:44 pm
If you're making under 200kw atw, is there any need to run coil packs?
Hello There
Quirky
Postby ATAl » Sat Jun 26, 2010 8:46 pm
I don't know at which level of power or boost the standard distributor set up will stop sparking properly, but the advantage of running coil packs with an after market ecu is that the spark timing can be changed a lot easier and you can do fun stuff like anti-lag.
As Matt said, you can use evo coil packs, but as far as I know you need an separate igniter unit for them and I wanted to make the ignition as simple as possible - the igniter is built into these coil packs, just run wires to them and they work.
ATAl
Postby metal_sean_head » Sat Jun 26, 2010 8:50 pm
ATAl wrote: but the advantage of running coil packs with an after market ecu is that the spark timing can be changed a lot easier and you can do fun stuff like anti-lag.
Now we are talking!!
VTEC: All of the lag and none of the boost.
89 AE92 FXGT
Big Port Redtop
TVIS!
19.8@32kph
metal_sean_head
Postby gasman » Sat Jun 26, 2010 10:46 pm
my distributor set up was still good for 272kW.
"What can possibly go wrong?"
gasman
Postby frost » Sun Jun 27, 2010 1:14 am
Rick wrote:You can also run them off the factory ecu, good for RWD conversions.
Crampy wrote:Been done with Honda K20A coil packs on stock Blacktops, stock ecu too. As mentioned, good for RWD, as you don't need the dizzy cap (no need to modify firewall)
can you point me in the direction this info is kept, ive been out of the 20v mods for too long and lost track of most of my good info spots,
Postby matt dunn » Sun Jun 27, 2010 1:50 am
I too would like to know how to do this,
especially since the factory ECU only has one output for spark??
Postby ChaosAD » Sun Jun 27, 2010 10:22 am
By connecting all four coilpacks to the igt signal from the ecu.
Like wasted spark but all four are firing at once.
I guess it might work with the blacktop being sequential injection, but its not really the done thing.
A better way to do it would be to build a small 'router board' which routes the igt signal to the right coil pack.
ChaosAD
Postby dusk93 » Sun Jun 27, 2010 10:38 am
I think dad was/is gunna make me a 'router board' to see if we can run wasted spark off stock ecu, will keep you guys posted on if it works or not :twisted:
Current: 1983 AA60 Coupe, 1987 E30 318i coupe, 1985 SA70 Parts Heap, 1990 R32 GTST Coupe
Ex: 1982 AA60 Coupe, 1987 AE92 FXGT (RIP), 1989 Mazda Astina BG hatch, 1994 R33 Skyline GT ( RB20E powered :( )
dusk93
Postby Crampy » Sun Jun 27, 2010 11:51 am
Club4ag forums.
http://forums.club4ag.com/zerothread?id ... 370#167370
Crampy
Postby TRD_ZERO » Sun Jun 27, 2010 1:18 pm
Sticky this.
Previous:
TRD_ZERO
Postby matt dunn » Sun Jun 27, 2010 2:07 pm
ChaosAD wrote:By connecting all four coilpacks to the igt signal from the ecu.
Dont think so as the cylinder would fire at BDC between the intake and compression stroke,
so all the fuel and air you have just sucked in would get fired at BDC.
You would need some form of sequencer.
Postby Bling » Sun Jun 27, 2010 4:48 pm
TRD_ZERO wrote:Sticky this.
Will end up in FAQ section for sure when everything has been covered.
Postby Crampy » Sun Jun 27, 2010 8:14 pm
Dudes have done it as per the Club4ag forums. Batch fired with the single output forn the ECU. It works.
It's not really done as a performance mod as such, it's more for the RWD dudes and not needing to use original dizzies or the expensive kits to change it's position.
Crampy
