do you need cert for braided brake lines?
Postby h8wrxs » Sat Jul 03, 2010 5:36 pm
do you need to get cert for aftermarket braided brake lines?
h8wrxs
Postby Leon » Sat Jul 03, 2010 5:42 pm
No.
So long as they are crimped or swaged fittings such that you can't take the brake line apart with spanners, then so long as they are in good condition you will get a WoF.
Postby d1 mule » Sat Jul 03, 2010 6:27 pm
they HAVE to have some sort of compliance tag on them too, i dont know what its called but i know they HAVE to have it
d1 mule
Postby Leon » Sat Jul 03, 2010 6:28 pm
d1 mule wrote:they HAVE to have some sort of compliance tag on them too, i dont know what its called but i know they HAVE to have it
That was correct for a short duration a great many years ago.
That is no longer correct.
Postby ChaosAD » Sat Jul 03, 2010 7:39 pm
what about if your getting a car revinned or certed? do you need a tag to prove they comply with certain standards? or is it the same deal as with a wof?
ChaosAD
Postby Leon » Sat Jul 03, 2010 9:22 pm
You do not need standards on a brake line.
You did briefly some years ago.
That was some years ago, not now.
So unless you're Dr Who, you're pretty safe if you have brake lines that can not be dismantled (because they are crimped / swaged fittings).
