So im going to buy an aftermarket fan, But what i was wondering is can i mount the fan on the front side of the radiator so that it blows cool air through the Rad?
Any cons to doing this?
Thanks Tyler
loudstealthGT-Four wrote:oh ok, yea thought about putting a fan there, but since ive removed the A/C in my car ive got heaps of room in front of the Rad. So was thinking would be a wiser idea to put it there, could also double as a fan for my front mount too![]()
Malcolm wrote:... Davies Craig ones, can have the fan removed and flipped so the air still flows through it the right way when mounted as a "pusher" rather than a "puler". Then you just wire them backwards so the motor spins the other way
loudstealtGT-Four wrote: ....but since ive removed the A/C in my car ive got heaps of room in front of the Rad...
RomanV wrote:Although if you want to get a car going instead of having it sitting in a garage for several years while you ponder such things![]()
Then stick it where it fits
dusk93 wrote:loudstealtGT-Four wrote: ....but since ive removed the A/C in my car ive got heaps of room in front of the Rad...
How much space are we talking? Like could you fabricate some new rad mounts so its mounted further forward so you can retain the 'suck' fan setup with a shroud?
Just a thought,
RomanV wrote:If you've got a fancy radiator that cools a lot more efficiently and holds a larger volume of coolant, it would be a pity to have an inefficient fan configuration that negates some of the gains.
