lowering options.
lowering options.
Postby Quint » Mon Jul 05, 2010 1:24 pm
Car is sitting high... really high. Have a set of dobi lowering springs that I could use. But from my understanding they are a softer spring.
What is the ideal options for lowering a car? Use a decent brand of lowering spring (suggestions?) and get the shocks shortened? Or will the dobis do the job just as well / such a minute difference to a whale that it wont matter.
atm, guards are 6" above the wheel, rivals the hilux for clearance :p
Quint
Postby tsoob » Mon Jul 05, 2010 2:31 pm
what car is it?
dobis are pretty good springs i have used hundreds of their kits with good levels of success so far
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby metal_sean_head » Mon Jul 05, 2010 3:31 pm
Do you just want it low? Or to handle well aswell? Track day car or street cruiser? and budget?
VTEC: All of the lag and none of the boost.
89 AE92 FXGT
Big Port Redtop
TVIS!
19.8@32kph
metal_sean_head
Re: lowering options.
Postby Mr Revhead » Mon Jul 05, 2010 4:16 pm
Quint wrote:atm, guards are 6" above the wheel, rivals the hilux for clearance :p
stop using space savers? :P
If you really do need to drop it 6"s ( :!: ) then the only way is going to be a serious set up as that much of a drop will alter your geometry massively! :o
Postby tsoob » Tue Jul 06, 2010 11:45 am
makita one ways :D
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby cat007 » Tue Jul 06, 2010 11:57 am
Yeha - good ol' MK3 suspension man - When I put lowering springs in my supra - I went down about 4.5".....
Sometimes supra's ride VERY high lol
That's assuming it is your supra?
And the suspension geometry isn't affected on Supras 'as much' as, say a Primera for example, when you lower it.
Postby Quint » Tue Jul 06, 2010 12:12 pm
Don't need it 'super low' just non -4wd material. If dobi aren't as shit as i thought they were will just chuck them back in, they are only a 35mm drop though.
AG springs are always tempting ;)
Quint
Postby XSVWGN » Tue Jul 06, 2010 3:33 pm
i have used dobis alot of times through my cars. They are the best so far and i have used jamex, sabre, louvells, kings and dobis. The dobis have a good ride height too
Matt
021 297 1754
2008 Kia rio - work car
XSVWGN
Postby Mr Revhead » Tue Jul 06, 2010 3:35 pm
Dobis are fine for road cars, if fitted to the right application!
Postby cat007 » Tue Jul 06, 2010 3:50 pm
Mr Revhead wrote:Dobis are fine for road cars, if fitted to the right application!
I've got cobras in mine I think. Quite firm and not as nice handling as I'd like
Postby Quint » Tue Jul 06, 2010 5:26 pm
Sweet, time to pull out the shocks for a 3rd time. God dammit.
Cheers lads.
Quint
Postby cat007 » Tue Jul 06, 2010 5:27 pm
Quint wrote:Sweet, time to pull out the shocks for a 3rd time. God dammit.
Cheers lads.
What shocks are you using? if you can, grab a set of bilsteins from the JZA70 R type supra...
Postby Mr Revhead » Tue Jul 06, 2010 5:33 pm
they were cheap as cheap can be through toyota :wink:
Postby cat007 » Tue Jul 06, 2010 5:35 pm
Mr Revhead wrote:they were cheap as cheap can be through toyota :wink:
HAHAHA
I think they wanted something like $800+gst per corner IIRC....?
Postby Mr Revhead » Tue Jul 06, 2010 5:38 pm
all Shocks are line priced, unless they changed it.
the bilsteins were $150 +gst rrp when I was selling them.
It may have changed....
Ask the forum sponsor!
Postby Quint » Wed Jul 07, 2010 12:20 pm
cat007 wrote:What shocks are you using? if you can, grab a set of bilsteins from the JZA70 R type supra...
Way ahead of you :p
Using JZA bilsteins and front hubs, though I may need to upgrade master cyl also, no brakes no brakes no brakes BRAKES.
Quint
