Charing 2 car batteries at once?
Postby cat007 » Mon Jul 05, 2010 9:49 pm
Howdy
I've got 2 batteries in the van I want to charge by tomorrow morning
The neg of them is hooked up to the chassis and I've currently temporarily got 1 jumper cable going between the pos terminals.
Will charging them like this put too much load on the charger? Or will it seem to the charger that it's just one really big battery and take twice as long to charge?
The charger has a cooling fan and I've never felt it get warm, let alone hot....
HUnt
Postby Akane » Mon Jul 05, 2010 10:29 pm
Sounds like you have the batteries setup in Parallel, which is correct.
It'll just take longer to charge, you can't overload a modern battery charger if my sources are correct, unless it's a short circuit, which they should have an auto shutoff / fuse for that sort of thing.
Postby cat007 » Mon Jul 05, 2010 10:36 pm
Akane wrote:Sounds like you have the batteries setup in Parallel, which is correct.
yeah, it's in parallel. Normally has a blocking diode but yeah, in this instance I've got them in parallel
cheers for that. Was hoping they'd be fine
Postby whynot » Tue Jul 06, 2010 7:31 pm
The only time this could backfire so to speak is if one battery is faulty because the faulty battery will pull the voltage of the good one down and prevent it charging properly
whynot
