Mr.Phreak wrote:gleem wrote:Ill be sticking to rwds from now on
Learning to drive might be a better option
gleem wrote:If not the steering arms could it be the alignment? just from changing the arms
gleem wrote:Now all that put back together the drivers side wheel will be dead straight ahead and the passenger eheel will be abit the left like half a steering wheel turn.
gleem wrote:On the passenger side the bit on the arm were the bolt goes through the rubber horozontally was bent on the surbframe not the arm.
gleem wrote:To change the camber be said he took the bolts out and did some grinding or something. Does some one know what he means as id like a bit more camber
